I'm selling my laptop, specs:
Compaq Evo Notebook N410c - PIII-M 1.2 GHz - 12.1" TFT
Dimensions (WxDxH) 26.6 cm x 24.2 cm x 2.2 cm
Weight 1.5 kg
Processor Intel Pentium III-M 1.2 GHz
Hard Drive 1 x 30 GB
Networking Network adapter - Ethernet, Fast Ethernet
Power AC 110/220 V ± 18% ( 50/60 Hz )
RAM 256 MB
Graphics Controller ATI MOBILITY RADEON - 16 MB
Audio Output Sound card
Cache Memory 512 KB
Display 12.1" TFT active matrix - 24-bit (16.7 million colours)
Telecom Network / modem combo - mini PCI - 56 Kbps
Battery Lithium Ion
Average Run Time 2 hours
Windows XP Professional (with all latest software loaded on)
Purchased 1 yr ago for $3199
Selling for $1500, (melbourne pickup only thanks)
https://www.sau.com.au/forums/topic/36565-fs-laptop-1500/
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
