  • Replies 61
Yes agreed...bit unfair to lynchmob based on one side of a story...from someone who believes 1 week is a massive delay (sorry OP, but that was a bad call). This stuff does happen but customers also get bees in their bonnets. Will stop contributing to the pen names now.
hahahaha funny stuff.
lots of lulz in this thread! :D
Even blind Freddy can see what you're driving at there :P
Hey why are you singling me out? Haha
Ruffels started it anyway :whistling:
FWIW i have no strong opinion on this issue, never had any paint/panel work done. As Birds said, probably not clear cut anyway
It seems to be common practice in the import scene that "another week" is a small ask and should be given when asked. This is simply a classic example of a workshop not knowing what it means to keep a schedule or prioritize things. I understand things can get delayed but workshops these days are getting to comfortable with giving bullshit timeframes leaving the customer out of pocket/no transport for a number of days he hasnt planned for.
The car should be ready on a date that is agreed apon before the job commences, there really shouldn't be any excuses.
There's more to the workshop than just labour working on your car. There is a mile long list of intermediaries responsible for getting that job done. Consider the wait for supplies, warranty issues with previous customers, stuff ups with work on your job etc. It's unforeseeable. If it was genuinely a cash job, from my experience those panelbeaters tend to fit those jobs in between other cars.
You won't hear people coming on forums and saying how "on time" a place was with their car, unless prompted to name one...but people come on forums and start threads complaining about businesses all the time. Communication with the customer, yeah, that can certainly be improved...but the delays themselves are normal. A workshop needs your money to pay their bills, so it's in their interests to get stuff done on time. A little patience does go a long way too...customers who rush workshops often end up with a rush job! I waited nearly 2-3 months for a panel shop to repair and respray half a car...I can't fault the job they did on it.
Again, not judging your situation here, just saying that workshops get hard done by when they don't get their say in the horror story...and most customers don't understand all that's involved in running a workshop.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
