I just bought this exhuast.
It's a 3.5" Inch HKS exhaust but I don't know what the internal pipe diameter is.
When they quote an exhaust as being 3.5" does that mean that the internal pipe diameter is this width? or is it smaller?
lol even if the outer diameter of the pipe of a 3.5" pipe was 3.5" you'd only be losing literally a couple of millimeters of diameter due to the thickness of the pipe itself
in conclusion it's completely negligable.
If its 3.5 i would be confident in it fitting, like i said, the HKS is slightly over 3.5inch anyway. They are 95mm (for R33 anyway, 34's appear to be 85mm)
Have you considered measuring the pipe yourself? That way you will know for sure wont you.
Okay so i'm trying to find out which ecv to buy to match my exhaust.
Apexi ECV - http://www.nengun.com/apexi/exhaust-control-valve
155-A014
Nissan - Type A - ID 67mm - Bolt 105-107mm
155-A019
Universal - Pipe Type - ID 80mm - Bolt 105-107mm
Anyone have any ideas?
Thanks mate, but I cab by measure the pipe because its in transit. I've seriously got no idea which ecv will fit.
i can't answer your question, but i will just point out that if you are putting in the ECV to make the car legal, it technically won't be. if the car ever gets tested they test the exhaust with the valve open. if you are putting it in to at least reduce the amount of attention the car draws and make it quieter to drive, then go for it.
Yep, i know that it won't make my car legal.
The problem is that i don't know which ECV will fit my 3.5" inch exhaust?
Nengun supplied the attached info sheet, and i asked them what the internal pipe diameter is but they haven't got back to me.
You can see that i've highlighted in red the area i'm trying to figure out if it's 89.9mm (3.5"inches) to see if it will fit my exhaust.
Anyone have any ideas or experience?
Edited by R33-RB26DETT
I think it says 67mm. You may have to go for the round slip on ones, the 80mm should be close to sliding inside the 3.5 inch pipe and the 95mm would be the only choice for larger than 3.5 inch, it would need adapters on each end. Perhaps you could hide it inside the cat body?
I believe pipe diameters are quoted as "inside diameter". So a 3.5" pipe has an internal diameter = 3.5".
this would make sense as different materials used for making exhausts would have different thicknesses depending on how strong they are
Ah well, i just ended up ordering this one
155-A014
Fingers crossed it fits, i'll post back here to let others know because it was seriously painful getting the right answers anywhere.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
