hi,
im new to skylines, (had mine a week) and have a few questions someone wiser could hopefully answer;
was wondering if i will damage the front diff setup by removing the fuse from the engine bay and making it full time rwd? (untill i finish my awd/rwd switch)
my car is a 1992 r32 gtst-4 with r33 (vg30?) highflow turbo, big front mount, 15psi, 3" straight pipe, brass button clutch + lightened fly wheel etc etc. its just had a dyno tune and only makes 144rwkw at all 4 wheels? i was thinking the power figure would have been much higher than that? it had a blow off valve of some description but i took it off because im not a fan, has given slightly earlier boost but still drops down to about 10psi by the time im in high revs.
the next thing im thinking of doing is a nistune ecu, bee*r rev limiter and an eboost 2. thoughts?
cheers guys.
Josh,
https://www.sau.com.au/forums/topic/365677-r32-gtst-4/
nope. common mod. get used to driving it in 4wd. it will feel a lot different than the RWD car you had,
as for modding it. search GTS4 on here . dropping another engine in is a bit different as a normal skyline motor will not fit. a stagea 4wd one does though. check my sig for a bit more info (I own a 89 2 door GTS4.)
https://www.sau.com.au/forums/topic/365677-r32-gtst-4/#findComment-5838906
First and foremost, welcome to the club of skyline ownership.
To answer a few questions;
A VG30 turbo is infact off a 300ZX, so it' either an r33 T3 turbo or a vg30 turbo. Your power figure does seem a little low, but keep in mind the awd system. You get a massive amount of drivetrain loss in terms of power (20-30%). Nistune is a good modification; it will tidy up your tune and unlock some more power. Also, you can get it retuned easily everytime you make a larger modification. As far as electronic boost controllers go, they're good but not essential and you can get by on a bleed valve without trouble. a greddy prospec was one of the first purchases I made for mine and I regret buying it before more important parts - like new coilpacks.
Anyway, enjoy skyline ownership.
https://www.sau.com.au/forums/topic/365677-r32-gtst-4/#findComment-5842776
Mine - fairly stock - produced 115 awkW (145 rwkW), so your 144 awkW is a pretty fair improvement.
You are probably not aware that the GTS4 does not run permanent AWD, unlike Subarus and Lancers. It only engages the front drive wheels under certain conditions - do a search to discover how the Nissan ATTESSA system works.
I don't understand this desire to disable the front drive. Frankly, if you don't want the AWD, why buy a car with it.
https://www.sau.com.au/forums/topic/365677-r32-gtst-4/#findComment-5842835
Welcome to gts4 ownership! I like them and am biased. I think the front diff and transfer case are fine removing the fuse. Why? You've now got posts from 3 different gts4, to stagea rb25 engine up graders. If you stay with the rb20, there is a sticky on turbos and upgrades in "forced induction performance".
https://www.sau.com.au/forums/topic/365677-r32-gtst-4/#findComment-5842981
  • 1 month later...
thanks for all the welcomes :)
*under closer inspection, its an r33 highflowed ballbearing turbo. so a bit of moneys been spent on it.
and to answer a feq questions, i like disconnecting the FWD setup when i want to slide it, and just bought and installed an Apexi AVCR, sooo much better! couldnt be happier with how the car drives now! no boost drop off in high rpms, more stable boost, comes on earlier and smoother etc etc. took a while to tune but well worth the money.
and why wont a normal skyline engine fit!? what about r32 gtr? they use the same awd setup yeh?
aannnddd, thats all the questions i can remember :) thanks for the help/inputs guys.
in the coming weeks im getting nistune ecu, 16psi, forward facing intake plenum, HKS adjustable cam gears (any one know much about driveability changes/performance *if any* from cam gears with stock cams??) catch can, bigger injectors and putting in my bosch 909 fuel pump (anyone know how many horsies a 909 will handle in an rb20?)
hopefully she'll boogie then :) been told to expect around 220-230RWKW? currently making around 180-190 i believe.
https://www.sau.com.au/forums/topic/365677-r32-gtst-4/#findComment-5896248
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
