Hey Guys i have a baby girl on the way and time to sell my other baby!!
Car: 1999 r34 GTT
Colour: Yellow
Transmission: Manual
Price: $20,000 with rego, $18,000 without rego
Milage: 33,000kms weekend car only as I catch a train Monday-Friday into the city
Please no test pilots or tyre kickers, please have your finances ready prior to inspection,
I am interested in swaps for a family orientated car, something of similar value straight swap or cash adjustment my way, must be 4 doors and have a big boot
Cars of interest: Mazda CX-7, Honda CRV, Honda Accord Euro, Subaru Forister or Liberty if you have anything else let me know and we can talk more
your can get at me by email on [email protected] I'll respond generally within the day
I'm generally avaliable after 7pm on week days if you were wishing to view the car or all day weekends
Pictures will only be emailed to interested parties at this stage so hit me up if your keen!!
Jesse
The list goes as followed
R34 GTT1999
33,000kms genuine
Been to 2 Skid Pan Day 1 dry and 1 wet
Exterior
Yellow with Bomex style side skirts and rear bar
Mu Secret Carbon Fibre bonnet
Project D Deep Dish Rims staggered offset (10.5" rear 9.5" fronts)
JDMyard HID Kit
Suspension
HSD Height and Damper Adjustable
Adjustable Camber/Tie/Castor Arms/Rods
Engine
Custom Exhaust system Headers-Full Exhaust with Varex Twin tip
Greddy 25g High Mount Turbo
RB25 Neo Motor
Aftermarket Injectors/Fuel Pump
Apexi Power FC w/ Hand Controller
keen to swap for a 1998 twin turbo gs300, ive got twin 12" subs in boot and still heaps of room lol. Ill send u pics if your keen
Hey - If you could email me some pictures and more details on the car such as milage, transmition type and if any modifications have been made to the car that would be good.
Email is [email protected].
Cheers!
hey bud can you send pics to [email protected] and to [email protected], There both my work and home email. Thanks bud
Sid
Photos have been emailed to both email addresses as requested.
Let me know what you think.
Cheers!!
    • That M3 looks like it handles so well, initial slight understeer on turn in followed by oversteer which is cancelled out as steering returns to centre. Looks like such a fun car to drive. In comparison the Skyline and Sierra look like they understeer more and thus need more heavier steering inputs...?
    • Gday   on the hunt for an rb25 gearbox and clutch to go into my R32 rb25/30 build happy to travel a bit or pay for freight for the right one From my limited research, think I need an rb25 driveshaft yoke to make it fit so I’m after one of those too located Bathurst
    • Common for single gauges to be swapped around. My 33 GTST when I bought it had a GTR tacho fitted, everything else was GTST gauges.
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
