  • Replies 217
Here is a vid check it out and see what u think !!!
I think the only person who did a better job of balking you was Sierra Sierra ! Lol.
Awesome weekend though, great time straight out of the box :thumbsup:
Well done boys.
Hello Ben.
No there is no tricks to the HKS CT230R except great attention to detail. It's been left how it ran on the track. There has been intercooler and radiator differences between tracks but otherwise untouched. It's all in the details and keeping the weight down.
You must understand that other cars have developed further since this car was on the track with the multitude of diffusers used these days. It would still be interesting to see what it would run against them even without further development in the last 5 years.
HKS always sets the benchmark with projects which takes others years to catch (R33 GTR Drag / S15 Silvia Drift / CT230R EVO Time Attack). All these cars were built and dominated the sport then retired. You then see others trying to still beat the records years after HKS have switched their focus elsewhere.
You are more then welcome to come to GT Auto's Open Day and have a good look over the car in detail and not under the pressure of World Time Attack. It can also be sold if the money is right but $130k doesn't come close sorry.
Cheers
Marty
Thanks Marty! One must wonder how the figure of 130 started to circulate!?
I'll endeavour to head over for a proper gander on the open day :)
Open Day Flyer!!
Cheers
GT Auto Garage
Keen to come up and have a chat to you guys about tuning my car and getting the bloody thing on the road here in Oz.
What time will the BBQ start ??
A few pics from the event the pit crew kept us motivated !!!!
By gtauto at 2011-08-10
You guys were rad out there. Great time for limited testing and never being to the creek before. Really enjoyed hearing and watching your car all weekend. Here's some pics i got of your 35. Hope to see you next year!!!!
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
