Hmm these flow more than the T04Z as a pair if its the HKS kit im thinking of... think equivalent of the lower spec T88 and T51's..
http://www.skylinesaustralia.com/forums/topic/308953-cams-to-use-with-hks-2835-52t-turbines/
  • Replies 88
yes i have been thinking about this to but on a 30/26, i think to get the most out of them you/i would need to spend $50,000 to get the car to move and another $50,000 to get a car to the point were you can drive it, even then i think it would be a pig of a thing on the street and would just be a expensive dick swinging exercise.
i think you should sell them (you get $1200/$1500 for them each) and get -5's, they will be all the turbo you need and the car would be alot nicer to drive but it would still be scary to drive to.
btw -5's cost $2000/2500 so if you sell the 2835's you can afford them ezy. :thumbsup:
Edited by tweety bird
agree but i seriously dont know.how it would cost you 100k plus car
Ever had a workshop build you a car instead of build one yourself? lol
Every small part adds up and every dollar counts. How much is a gearbox to cope with that much power, 10k? Or am I kidding myself and its probably more... How bout the clutch, drive shafts, diffs.. Put a hole in 20k yet? How bout your motor, you will put a hole in 10k on parts alone to build a 500rwkw motor, call it another 10 on a decent head setup right? I mean were talking round figures once you add up all the loose ends... You don't reuse bolts on a big build motor you realize..
Then what, you gonna use stock manifods? Or fork some good coin on something like 6boost items. Had a read of the recent 6boob manifold install thread for a GTR? All the niggly little problems that the guy went through, imagine paying a mechanic to do that for you.. I haven't even scratched the surface..
Building big cars requires bigger wallets. Even building a basic bolt on car cost a small fortune, I think one thing this website needs is a basic price index.
Anyway, GL to OP.
Yeah maybe if the shop was doing a ground up rebuild of the entire car....
It's ballistic money, and not what I would consider amazing value, but what other people do with their own money is not really my business :)
My RB26 made 411rwkw on high mount 2835 52T's on a built engine at 'only' 16psi. Came in at 5,300, full boost at 6,000 and went to 9,500+ power still rising, using 280° 11.5mm cams.
as others have said, I wouldn't use these as a 'bolt-on' upgrade.
If these are the ones off my car (which I'm guessing they may be) you will not make 450+kw with them unless you go all out porting the head etc.
They made 530rwhp on my car on 24psi. Stock head, stock cams. They hit HARD at 5500rpm and are a lot of fun.
As for an overall setup, I prefer the T04Z I have now, as it seems a bit more responsive and makes closer to 600rwhp, albeit it's a bit more linear.
These twins will be great, but you need to spend the coin on the head to make them work.
I was just about to start a topic on building the head. What cams, how much lift, over size values etc. As much info as i can find. Or preferably buy a head that's already been built for something similar.
What i had picked up is around 270-280 degree cams with around 10mm lift, over sized ex valve...
Sounds to me like you just want to be able to say i have twin 2835's on my GTR..... bragging rights are great when you tell people you make 500rwkw with twi 2835's, but it all goes to shit when your mates 250rwkw SR leaves you in his tyre smoke because you have so much lag
You will not be happy with them and your car will not make 500rwkw on a basic engine build
As has been said before, head work will be mandatory to make this sort of power and it will have to be done well to work properly. Prepare to spend about $3k on porting alone as a base price. you could spend less but the time spent on a head to support 500rwkw will not get you any change from $3k. You will then need to have some pretty decent hardware in the head to make it all stay together
The bottom end will need to have some decent bits put into it and again, will need to be put together by someone who knows how to build an RB26 properly. To make 500rwkw with this turbo set up you will need to spin it to over 9500rpm and it will need a considerable amount of boost to do it as well. I am not talking 30psi+ but you will be stretching pump fuel limits to make 500rwkw so consider switching the car to E85. A standard crank will put up with 9500+ for a short time but it wont do it for ever. Consider buying a Tomei/Crower stroker kit or something similiar. Be prepared to spend about $6k on parts, then assembly.
A gearbox and clutch will definitely be on the cards. A PPG gearbox once setup will cost you close to $10k, then about $3500 for a quality multi plate. I wouldnt use a synchro box, i would go dog with that much power which means a maintenance schedule then needs to be adopted to maintain the dogs engagement etc You would probably be looking at 10,000klms max between services for a dog box
We havent even started on fuel system, engine management, cooling etc
I dont think people realise just how much money you need to spend to support 500rwkw reliably. I would budget minimum $50k to build a car to support this much power.
If i was you i would be selling them off and getting a hold of a T78-33D kit, or a TO4Z kit. We make 460rwkw on pump with a T78 and with head work we see boost at about 3000rpm, on full boost no later than 4000rpm. A twin 2835 kit, even with head work, will not see boost before 5000rpm and that makes for a very very slow car
whats wrong with them?
Lets start again. Ok. If i budget 10g for the head. Would these or a t04z be better for a street driven car? Will i have to go as full on building the head if i use a t04z. What kinda power figures will you pull from a 04 wi i the 0.81 rear housing? I'll be using a hks version not a garrett or other brand.
no point having a well done head if your bottom end cant hold up to the power.
i wouldnt wana push any more than 350kw out of a stock bottom end.
just for example, a CRD full race head is about 9k + using full jun catalogue with 280* + cams then you still gota add a intake plenum ontop of that price. Hypertune plenum n throttle body is $2600 + install so there is an idea of how much you will be looking at.
also throw a tune on top of that so say a full tune is another 1k +
Hey mate,
10'000 is definitely enough money to get you a nice fresh head with plenty of work.
T04Z will be an infinitely better proposition on the street (I prefer twins and I still say this)
you get all the bonuses of a single turbo, packaging, ease to work on and set up, reduced costs and conversely you would get none of the bonuses of a twin setup with 2835's.
I see only benefits here mate, especially for a street car.
I see no reason why you couldn't make an absolute minimum of 400AWKW with the HKS turbo, probably substantially more then this.
As for my opinion, I reckon go HKS 2530/ GT2860-5 for a very responsive 420ishAWKW.
Cheers,
Mitch.
Well for my 2c I've seen people get what they think is a reasonable compromise from an externally wastegated GT3582R on RB26s . The last one I went behind was in a VL and it was typical RB26 in a reasonably light (1400ish) car .
I don't think it had big cams and felt reasonable with a 1.06 AR Garrett turbine housing .
The owner reckoned it was scary fast and borderline uncontrollable on full boost .
Poor fella , his missus works in an Audi dealership and brings home toys on weekends . He said she lined him up in some sort of TT V6 AWD auto thing and absolutely wasted his pride and joy ... Dreams destroyed he didn't keep the VL for long after that .
Yea the bottom end has the works. All except extended sump. But has a baffle kit in. Got forged pistons, rods bearing what ever else i got in the build. It was a head gasket down build. As nothing was done with the head except for a face pressure test and what ever else they did to it. As at the time i was un certain of the direction of the car!
Guest
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
