CAMS have finally have a revision of the ancient Shedule J section of the manual.
There is some changes in some areas that I know effect a few people on here.
Ryan (BOZZN) Neil and Pete (FATZ) really need to organise their pre log book inspections and register their cages as they will be needing modifications come sept this year to comply. There is also an R35 in the R35 section which I noticed today that wont pass without extra gussets being fitted to the roof members (due to the rear diagonals coming from the center of the hoop not the outter ends)
I know of alot of cars being built around the place which wont be finished by the end of this year and have got cages either half done or fully done that wont comply. Those guys should really be making sure the places doing your cages understand the new Shedule J and make changes to make sure you will get registration.
The fundamentals are the same, the material specs are the same, a few of the bar members allowable positions and intersection points have been changed (prodominantly windscreen/door jam support bars) Also intrusion bars are having a strong recommendation put on them to be a two bar U design with opposing gussets instead of the 3 bar cut type. compolsary X supports in the roof for two person events (such as rally etc) Also compulsary X diagonals in the hoop or rear legs instead of the old single diagonal required rule.
The shedule is more based around the FIA regulations now which have also recently changed.
Just a heads up really for anyone looking to get a cage done, make sure that the manufacturer is aware of the new regulations.
https://www.sau.com.au/forums/topic/365763-cams-shedule-j-overhaul/
  • Replies 52
Posted Images
Current log books are fine, however im told there is changes to minimum requirements for saftey cages depending on the nature of the event, some of which will be enforced log booked before or after. ( not sure how they intend on doing this but oh well)
For example racing of various levels will require various types of intrusion bar. They have categorised different levels of racing and made a set of minimum rules for each level so to speak. Club racing will get away with single intrusion but any state or national meeting a X intrusion will be required etc.
Any two person event (targa or rally etc) will require a full roof X (same as the old FIA regs)
There is heap or categories and crap but I havent had time to go right through it yet.
I think there is a few technical buletins floating around on the CAMS website refering to the new regs but
I do have the 2012 PDF but I dont know how to post it. Tell me how and ill put it up, I have it as an email....
Ryan your car might fit into 2F production sports. If its not on the list already (R33 GTst) then you could check the dimensions CAMS specify in the 2A regulations and apply to have the R33 added to the list pending production numbers etc. I didnt check to see if it is on the list already.
You can find the reglations for category 2 cars here CAMS category 2
Alternatively you are going to have to do it as a sports sedan.
Also remember the car needs to be completed before you organise a log book inspection. All regulations for the category you are applying for need to be meet. Emergency shut offs, extinguishers, window nets, blah blah.
You cant just get someone out to look at the car and say yep it has a rollcage its log booked.
You'd probably know already but at the bottom of this page there is a list of pre log book scruiteners. Best thing to do is contact one close to you and see what they have to say about the car and what they'd like to see done to it.
The online manual has both the old and new regs under general requirements.
My suggestion before firing up the glue gun, if you're long in the torso and anywhere near the roof, check, check and recheck helmet clearance with the FIA/sfi foam installed, which is not far off requirement either.
Glad we have some time to sort the car out. I'm thinking I'll put the car back together basically standard,,,log book it as a sports sedan and then convert to Targa spec.
Everybody this cage change is very important,,,after the end of Sept if you don't have a log book,,,lifes going to be a real expensive bitch.
Ben I'm not totally sure but you need to find out before the dead line.
I think I'll sticky this thread as I know some of you are AASA log booked and may well need to look at getting this sorted.
Cheers
Neil.
You can registeer a cage with CAMS without completing a log book application yes.
But it's only a form that gets filled out to have the cage acknowledged as being in accordance to shedule J.
It means nothing if latter on you want to log book the car for a specific category.
Tomorrow when I get the time I'll cut and past the major changes in the regs that I can see effecting people with "old" cages.
One big one that's worth mentioning in laymans terms
If the distance from the front legs base to the top bend in the front leg at roof height is greater than 200mm in a side on projection ( pretty much every tin top and skyline etc) it will require a drop bar which meets no more than 100mm from the front leg/windscreen lateral bar and travels to within 100mm of the front legs lower base. Can be bent in a front on projection but must be straight from the side.
Ryan, Noddy in queensland has his 33 gtst log booked as 2F production sports. I am not sure if the local club ever put it on the CAMS list but they should have. I think it is a good option for 33 gtst.
The other option would be 3J (IPRA). Apart from the restrictor your car would be OK wouldn't it? I am pretty sure IPRA will drop their restrictor rule sooner or later.
you can get the cage cams certified without a logbook can't you?
Not really. Cage certification is just the cage builder confirming it meets requirements on the CAMS paperwork. It is a pre-requisite to getting a log book but meaningless on it's own.
Cage certification will be very important for all the rally cars converting from AASA...
I just read the class 2 reqs again and wil need to have a chat with whoever is going to sign this off and see if I will fit in anywhere maybe 2B? Will keep reading. I just don't know about the different bumper and inlet manifold?
Cheers
The person who inspects the car probably won't be that helpful. They don't get paid by CAMS to help you, I've found alot of scriuteners to be painfully difficult to deal with at times particularly if your unsure or after information, they just expect you to know everything.
There are exceptions, mike Hanley is great to deal with, best thing he lives in my street and is easy to work around. Duncan knows mike all to well ;)
I don't think he is doing ore inspections now though.
Like Duncan and I mentioned 2F is the category for your car. Unless you go ipra ( pretty sure you can unless you have fitted a floor mount pedal box now?) If there is 2B cars getting around then the skyline can be a category 2 vehicle.
It's a bit off topic....but SAU:NSW are chasing up approval for 2wd skylines to run in 2B/2F: http://www.camsmanual.com.au/pdf/02_race/c.%202nd%20Category/RA18_Group_2B-2F_EligibleVehicles_Q211.pdf . They are definately not approved yet.
CAMS pointed out they are some of the only import models approved for 3J (IPRA), but I beleive those regs are anti-turbo enough that very few people would consider the class until it removes the restrictor requirement
Link here for members: http://www.skylinesaustralia.com/forums/topic/366527-cams-logbooks/
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
