So you were testing out these brakes for the first time on Sunday @ Sandown as well?
I had a similar experience, very happy with the brakes but they definately need a good bleed after the dry sessions later in the day.
The brakes got a damn good punishing and I'm using Penrite SIN (600f)... I might look at some cooling next up (UAS deflectors maybe?)
BTW your R32 looks and goes hard, very nice work in the engine bay too. I'm glad the first run on the track with the brakes and engine went well for you.
You've got some of those GTR boys looking worried! :thumbsup:
They were good except the first dry session when I actually could brake hard I had massive fade. Using Motul RBF600. Gave it a good bleed then it was great for the last session (hardest braking). I'm happy so far.
  • Replies 62
Posted Images
That's what I'm aiming for :P
Actually I forgot about 1 problem I had. The pad retainers are made from very cheap metal. It snapped during install. Luckily Ace workshop had a nissan retainer that fixed the problem.
Installed these yesterday. Was surprised just how easy the install was, everything bolted up perfectly. Only used one shim on one of the bolts on one side and all lined up well. Yet to drive on them, will report back after Sandown on Sunday.
Re the "gay colour", can get them in black if you import them (unsure if they can be found locally).
post-32498-0-84085100-1309769033_thumb.jpg post-32498-0-31751500-1309769062_thumb.jpg
Hey man, looking at your pictures something struck me pretty quickly... The direction of the grooves is running the wrong way around... Did you fit the rotors correctly?
Also to the OP, do you think what happened to you was just bad luck or is it something which could happen often and overlooked? I plan to get a set of these for my car but have no idea about what anything you wrote means... Are you basically saying the rotor did not sit flush? The thickness is not the same the whole way around? What is this run out stuff?
It doesn't matter which way the grooves run, it matters which way the vanes run.
Edited by R32 TT
What he said. The grooves on the K-Sport rotors run the opposite way to most. The rotational direction is clearly marked on the packaging.
Which bit is the retainer? On my G4's the pads are held in by two bolts inside two thin pipes, and a spring clip sits between these two bolts and rests on the pad. I cant think of any bit that would snap easily - are the K sport the same arrangement?
Due to adverse weather conditions, I was not able to fully test out the brakes at Sandown.
I made the mistake of thinking that I had sufficiently bedded in the pads on the street. After 1 hot lap I had major brake fade at corner 2 resulting in an off :( No damage though, so it was alright.
Only got one more dry session and was not really leaning on the brakes because I was still learning the track (first time at Sandown).
The brakes felt good though and I am looking forward to giving them a proper test at PI in August.
  • 3 months later...
G'day guys, beel lurking on the forum for a few years now.
Just thought i would add my experiences to the KSport discussion.
I got the first fit of Ksport 8 pot fronts AND 4 pot rears on a supercharged V6 Mitsubishi.
In summary found Ksport and AB Motorsport to be very reasonable to deal with.
They were the only company interested in fabricating a front AND rear setup for my car.
I could have fronts in any shape or form that I wanted in a few brands , but only KSport agreed to make rears as well..
(the rear handrake drum assembly is the show stopper for most brands)
Fortunately I had a full rear axle off a wreck for them to use as a mock up for the prototype.
They picked it up from me in Geelong and freighted it to Sydney...at their expense....both ways.
They returned it two months later, complete with a full 8 piston front / 4 piston rear kit which includes high quality braided lines etc....instructions, washers,spacers,etc etc etc
I was impressed with the quality of the kit and still am 20,000k's later.
But...It's for a street car with ocassional private road use...but it is a 13.xx second supercharged vehicle running 12 psi, so it does frequently stop hard.
Around Geelong and melbourne i often saw obviously very capable cars with great looking Brembos at the front and silly looking hand red painted rear calipers.
With Ksport I have four high performance brakes, that stop like a mountain goat at the edge of a cliff.
About the only criticism I can make, and it is a trivial one, is that the installation manual is a poor English translation.
"Install bolt XYZ very tight, do not" You get the idea.....LOL
I say they are great value for money and perform well.
cya
Here's a couple of pics of the drivers side.
Edited by z80
  • 5 months later...
Interesting thread thanks guys. Starting to think about upgrading the Brembos also...
not totally relevant but thought I would put this link up here for an intersting read. http://www.stoptech.com/technical-support/technical-white-papers/-warped-brake-disc-and-other-myths
Good to see you got it all worked out in the end. However, I reckon you are tripping out over the discs not being within the tolerances? I've fitted cheaper disks with 2mm difference in roundness and you will get NO vibration or anything bad. Only the contact sides of the rotor need to be close to perfect.
You've been stressing over nothing! :)
  • 1 month later...
Does anyone happen to have the measurements for these brakes, 330mm kit top of caliper out from center.
The rims I have at the moment, even though they are 17's, have a narrow barrel towards the spokes and require a caliper / rotor combination that sit a little more snugly. Fitting r32 gtr sumitomos and with 324mm discs and dogbones the top of the caliper fouls on the inner of the barrel, not the spokes.
I have tried to get a template, or measurements for this kit but they seem to be unavailable.
  • 2 months later...
  • 1 month later...
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
