Hi Crew
I have started doing my own days again.
My business name is TRACKSCHOOL http://www.trackschool.com.au/
The next day is the 16th JUNE 2011 at WAKEFIELD PARK.
I will be running very exclusive days at the private central coast facility very soon 1sm213sharepopcorn.gif
Price
$265 per person
Track
Wakefield Park is a 2.2 km racing circuit which is 10 km south of Goulburn and is a purpose-built closed road track environment which simulates typical driving corners.
Vehicles
Use yours, or enquire about using one of our Type R Vtec Honda Integra's with full roll cage, Nissan GTR brakes, H&R Coilovers at an extra cost.
Track amenities
Ample car parking, canteen, coffee shop, carports, lock-up pit lane garaging, tower, timing and corporate area.
Price includes
*15 minute sessions
*$10 lunch vouchers for use in raceway cafe/canteen
*Experienced race drivers/instructors including John Boston, Ian Dyk, Dean Evans and David Sieders. (Instructors may vary on the day)
*Theory sessions are held throughout the day for those who want it
*Timing
*Group organisation
*Drivers will be divided into groups according to speed and/or experience.
Clothing requirements
Please wear closed in shoes, socks, long pants and long sleeve shirt.
Bring a helmet (helmet hire is available).
Track School 2011 Wakefield Track Days
April 7th
May 12th
June 16th
July 13th
August 3rd
September 28th
November 16th
December 14th
Book Now
https://www.sau.com.au/forums/topic/365799-trackschool-with-john-boston/
Vehicles
I'm interested in doing one of your events and using your car. My question though is what happens if I pay and your hire car fails after say 1 session. Do you put me in another car,,,or send me home and re-imbruse me for my loss of fun.
Cheers
Neil.
I'd recommend the little integras to anyone. They are actually fairly quick cars. I did some laps in one last day boz ran. You'd have a ball in one Neil.
Get both of them hired out and have an integra challenge!!
John does spend alot of time and money maintaining them, if they need anything at all it gets done. I rekon they'd be better maintained than alot of race cars that we see getting around. They are far from regular circuit hacks that get run into the ground ;)
Vehicles
Cheers
Neil.
I am sure we will be able to work something out Neil.
And I hope you don't crash.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
