Hi guys, im new to the forum but just recently bought a r32 with a half started rb25det conversion. Anyways i was told it was a r34 neo engine (which i was sure it wasnt). But now I need help identifying what I actually have so i can buy the right coil packs and power fc etc for it. I have tried googling the ecu numbers but nothing comes up.
So the ECU number is MEC-R521 A1 1077 and the wiring with is seems to be right for it. I was thinking it was a series 2, but I found a broken igniter that seems to fit the harness in the boot amongst a whole heap of other parts.
Heres a link to the car i bought
http://www.boostcruising.com/forums/index.php?showtopic=731643&hl=
and heres a pic of the engine sitting in the car:
Edited by dantheman88
https://www.sau.com.au/forums/topic/365834-help-identify-my-engineecu/
i think it should be a rb25det series 1 motor, the ignitor on coil cover lines up, the cas, and some bolt patterns/pipe plugs on the cam covers show its not a neo, i dont have half the bolt patterns or plugs on my neo.
Isn't that just for vin numbers? It's a conversion so it won't match anyway
What would I look for then? Is there anything on the wiring loom or ecu that would maybe show a difference between a series 1 and 2 besides the igniter? Or maybe take the ecu somewhere to see what power fc would fit it? Or do the series 1 and 2 Ecu's use the same Power fc's?
if you take the head off, and you see the pistons, you can tell if it is a r33 rb25 or a r34 neo rb25, different pistons. and im also trying to figure out how to tell a series 1,2 and neo apart from one another.
  • 2 years later...
Are you saying all r34 rb25det are neo's?
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
