31 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Jonno, looks quite decent! Haha! Yeah, wreckers ahoy... Now coilies and rims :P
Drop clutch to see if rwd lol?
cannibal, cosmetic work like bonnet and bumper are black, vs blue car and both are dented from some sort of impact, both front door trims are gone, front seats are bucket, drivers torn, tight as f**k - not daily spec and when you turn while parking, steering wheel doesnt go back straight... Tiny little oil leak that I'm not worried about.
ahh decisions decisions.. :P
  • Replies 308
Posted Images
Lol yea, I can picture me driving along and bits falling off it... We need the topgear cobbled pavestones lol.
Sweet as on rwd! I want an AE86 so bad, but they command so much money.... Saw a supercharged one tonight in the right panda colours, just missing Fujiwara Tofu Shop on the side =/
congratulations but its FWD..
Me and my mates used to have bomb races, I had an 82 leone, piad 900, there was a 81 honda civic he paid 800 and a gemini they were all manual and all slow as f**k, we would line em up and see who could hit 100kmph first, it was like real racing in slow motion :laugh:
my old ute had 480 on the clock when I traded it. in its lifetime it went through, 3 sets of tyres, 2 clutches; 3 sets of front brake pads; 1 new head. Plus lots of oil and spark plugs :
i used to flog it pretty hard and carry 1 tonne plus loads,it was still running great when I sold it but was blowing a bit of smoke, may have needed new rings soon but would of cranked out another 50,000kms easy probably more and the suspension bushes and shockies were fairly shot, like driving a tugboat it rocked n rolled around alot ,there is plenty worse cars on the road though . But It felt a bit unsafe to me so i got a new one with airbags :)
This is slightly awkward,
the car is actually a 1986 E80 .. without an immobiliser .. and by WA Laws illegal if this is the case ..
Fail?
The seller said he may take the car back cos he feels bad and advertised it wrong etc
We shall see the outcome ..
Yeah I'll keep my eye out for a rego'd ke70 I do like those cars ..
R31's are nice too but unless its a real good deal their a bit big and since I'm paying for fuel and everything (on a crappy $100 bucks a week salary) ... i'd like something a bit more economical
Will probably keep looking for a good old Corolla or Pulsar or even a Ford Laser
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
