hey alll! i need some help hereeeEEEEE pleasee!
i drove my car 2 days ago and was haing trouble firing up after a few cranks it will start, and was turing over fine!
now i try to drive my car it will turn over but the lighting are very dim and now it wont even crank.
can anyone help me i have no idea!
PLEASW HELP ME!!!!
https://www.sau.com.au/forums/topic/365869-my-car-wont-start/
This statement is self-contradicting. "turn over" and "crank" are the same thing, so you must mean it will crank but not start.
In any case, the battery is on its last legs. The ECU requires a minimum voltage to stay alive (about 7V, I think). You may be using so much battery voltage just to crank the engine that there isn't sufficient to fire up the ECU, so the engine doesn't start.
It could all be the result of a loose fan belt. Check the fan belt tension. Then get a jump start. Then go and get a new battery.
Most battery tenders can test alternators. Some shops will test them for free also. That will rule that out.
OH NO~!!! problem i charged my car worked for one nite the next day its gone again .......
what can it be....alternator... ????
help help !
peaces!
Chris!
you could have a dropped cell in your battery mate
straight off the charge it will start the car but let it sit for afew hours and it wont start the car
If it was the alternator it would just die when driving. i have a dropped cell atm and its definetly on its last legs
only fix is to replace the battery, as above go to a battery place or super cheap even do it and get your battery tested.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
