Sure SteveO post away. An Ben I wouldn't do more than 10 or 15 minutes really. Believe it or not it gets repetitive and boring after a while. I had about 1.5 hours of footage to cut down for that 6 minute clip. Trick is to only have a few long segments and mostly 3-5 second clips.
Thanks for the kinds words guys. Oh, we should post it up on PI facebook too.
  • Replies 69
Well done fellas, looks like it was a great day.
Will try and come to the next one to give you all some competition. I'll try and bring my offsider also who will give the top of the tree a shake and give you someone to chase.
Great to see so many Nissans being used to their full potential.
Will get it up to the shop to get it weighed JP, think i just need an audience to perform. :action-smiley-069:
Nice Vid Eric, but wheres the silver Zed?
What program are you using there?, just trying adobe premier elements but not real happy with it.
Greg's black wide body S15 looked fat and fast, I will give him a run next one as The Slot Car was way off it's best, all new set up and got it wrong as understeered badly all day. I ran a little better at the NSCC day there the next day with a 1 min 6.1. Well ran day and nice weather. Well done again Michael Hill, faster again to.
Wizard either your car needs corner weighing bad or you drive smoother and faster with females on board,LOL.
I will be at the next one keen as.
I use Corel VideoStudio X3. Easy to learn (as video editing goes) and plenty of functionality.
90% is just trim clip, insert into timeline, dub music then throw on some titles and transitions.
Of course that still took 2-3 hours of editing for 6 minutes output.
Yeah time consuming, but enjoyable when the finished project is up. :thumbsup:
Will have a look at Corel, thanks.
I was also confused with the groups to. When I was at the NSCC day at Wakey the day after, which ran very similar to SAU, although instead of coloured dots, they write with white pen a number from 1 to 5 on your windscreen at scrutineering, according to you and your cars times. 1 being the fastest down to 5. This made it so much easier to know when your session was coming up, rather than trying to remember when hearing the call for groups and thinking. For example. Ok yellow is out now and red is next I think then blue or was it green or?? Colours don't have order numbers do.
NSCC did not however issue individual numbers for each car, unlike SAU- Renew which is very professional and handy. I kept my lime green SAU issued number 300, which was appropriate and easy.
Hopefully next Wakefield can mix both points together. To group people in numbers and to also give people individual numbers. Grouped numbers allows drivers to know when they are up. Individual numbers helps photographers and for the drivers again to pick out their lap times on the screen.
Depends if it is being watched to see what happened on the day or to see how individual cars handle and perform on the track...
I was also confused with the groups to. When I was at the NSCC day at Wakey the day after, which ran very similar to SAU, although instead of coloured dots, they write with white pen a number from 1 to 5 on your windscreen at scrutineering, according to you and your cars times. 1 being the fastest down to 5. This made it so much easier to know when your session was coming up, rather than trying to remember when hearing the call for groups and thinking. For example. Ok yellow is out now and red is next I think then blue or was it green or?? Colours don't have order numbers do. NSCC did not however issue individual numbers for each car, unlike SAU- Renew which is very professional and handy. I kept my lime green SAU issued number 300, which was appropriate and easy.
nscc had car numbers
ah was going to say same but you beat me to it, looks like there was a few guys who did both days?
i would have but couldnt afford two track days in one wknd (thanks credit card debt..) so really pissed i missed what sounded like a great SAU day, still managed to get a PB on the sunday of 1.13..6 and that should drop to 12's next time with the new tyres i got yesterday (400 dollar Pirelli...somethings)
nice video Eric, well done!
Patrick I ran Pirelli Corsa P-Zeros and was surprised they weren't that much better than street tyres. I need to stump up for some real Semi's now. Well done on a 1.13 that's about what I run in street trim. I gotta lurn to steer betta.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
