Its hardly ever the parts that fail/wear out most times. Its how its all screwed together and the tuning.
You could put the best pistons and conrods in there and if its not built right or tuned right for that matter too, it will still suffer a premature failure/wear out.
Dont get so worried about the parts youve chosen. Just make sure your builder hones the big ends and small ends to suit desired bearing crush for big ends and pin to bore clearance for the small ends. Make sure they are balanced end to end as well.
So long as he does his job properly you wont have any issues.
Ignore most of the smack talk people say in forums about rods and pistons and the rest of that shit. Half the people have no idea anyway, its usually something they have heard from a mate, or what their mechanic has told them(who isnt their engine builder, though you will find the tuner will blame the engine builder and the builder will blame the tuner, unless they are one in the same). One person will have a bad experience, that expereince will have the cause incorrectly blamed on a certain part because of rumours, despite other people having success with that same part. Suddenly forums are filled with trash talk with no real evidence provided and then you will base your decision on this after reading said forum. And you will throw away hard earned money because you believed it.
Its just like tradies and their tools!
Keep and use the rods mate. Nothing wrong with them.
Well said.
Plus there is no reason that rods wont last forever if they operate within the design limits. The problem with off the shelf rods is that they are usually designed to be as strong as possible and rated by testing in a high HP engine. Its just to hard to optimise rod design for each engine without knowning all the variables (max rpm, torque, location of PP etc etc.
PPM here in vic sell a decent rod for the price, made over 500awkw on them so far.
seen a manley rod in a SR 2.2 stroker let go (460rwkw 8500rpm) so we dont use them, could have been a one off but if other rods do it easy ill stick with them..
Now I'll swap my manley rods for your eagles!
if you really need to get piece of mind just get new rod bolts and relpace the little ends.. end of story. any word on replacing your tired old valve springs? they have the hardest job of the engine..
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
