Hey everyone, simple one, I'm looking to see who recommends what engine builders here in SA.
I've dealt with Lewis Engines before, but wasn't super impressed, plus i've heard mixed reports. Ideally looking for a Nissan specific builder. Someone who takes care and has the right equipment to build a reliable RB.
I have heard of Allen Engineering in Mallala, and apparently they know their Nissan engines.
YES i'm on a budget, i dont have unlimited $$ for this, at this stage i'm looking to chat to the builders, decide on one, see what engine components they like to use, order them, then give him my head and block and let them work their magic.
Give me your opinions, thanks.
NOT LOOKING FOR ANYTHING INTERSTATE. Thanks.
https://www.sau.com.au/forums/topic/365947-top-notch-engine-builders-in-sa/
I used Rhemac for my machining, they also do assembly also, however they are a bit pricey. Other then that I would suggest Lewis Engines, I shall be using them for my head work.
Boostworx, and Willall also do assembly as far as I am aware.
Yeah i have heard of Rhemac, and have just been speaking to a mate about them. But yeah he said they are quite pricey.
What machine work did you have done and what was the rough bill?
I have used lewis before, and yeah wasn't too greatly impressed. Plus i've heard some horror stories as of late too.
Check out my build thread :thumbsup:
but to give you an idea
Hot Tank Block and Crank
Grub Screw Crank
Mirco-polish Crank
Bore and Hone Block
Line hone block and girdle with torque plate
Check Rod and Crank Bearing Crush
and a few other things...all up it was just over $2.2k
Also, if you want top notch, your going to pay for it.
I'll be using Lewis as my tuner is friends with them.
go visit James from Nispeed, he is a Nissan performance engine specialist up at Modbury just down the road from Morpowa
if u can track down Peter Hall (ex Willall) he is also one of the best, they both built my forged rb25
im now at Morpowa
Wow Aberax, a little pricey yes. I had similar work done to my RB30 block for half the cost through lewis engines, but eh his work wasn't that great.
ovrtym33 - I've heard of Nispeed, but havn't really heard about their work. I know Peter Hall and have heard of his work, a mate also got his bottom end work done by him, and neither myself or my mate were overly impressed with what he did. I think Peter's knowledge is well and truly L series stuff. But i might have a chat to them anyway. Plus Peter is impossible to get a hold of.
Can you elaborate on this? Did you have a personal difference or was the machining sub standard (if so in what way).
I had my motor built at Boostworx, and havent had any issues with it at all.
its been going strong for 2.5years now and for the last 18 months its been a 300+kw RB26
When I was building mine all that time ago i asked Manta what they would charge and it was a little steep for me.
But boostworx came within my budget
It wasn't that bad, i just think hes more a get the job done as quick as possible, get it out. I dunno maybe it was his attitude. I've also heard some not so good stories about other people. Apparrently he built an engine, rod failed due to not being correctly torqued, but he blamed it on the tuner - being pre-detonation. Customer got no warranty or anything. But yet it was a workmanship failure, not tuning.
Boostworx, hmmm yeah nah, i'm sure they do alright, but they send their machining work to someone else as they are a performance workship, not a dedicated engine builder with all the necessary gear to build engines.
I've just been on the phone to Allan Engineering, he seems to know his shit! For the power i'm chasing, he really thinks i should stick with stock rods, JE or CP pistons, change the exhaust valves and a few other things, nothing too major for the 400kW MAX that i'm chasing.
Also spoke to knight engines, hes not too sure about using a Tomei pump, he seems to think the stock pump with billet gears are good, hmm i'm not too sure about that. But he said the same, JE or CP pistons, he said stay away from eagle rods, go with something like a SCAT rod (which Allan said not to). But he was also saying something similar that i wont really need to do heaps of head work and such to achieve the power i need.
If you call every workshop in town you're going to get mixed thoughts and just end up confused.
Ahh yep! I was aware of this lol.
Just spoke to Andrew from Rhemac, he seems to certainly know his stuff! Hes gone against the other two and said that Eagle rods are fine for the power i'm chasing. So there another mix up there.
But he also said for the power im after, head work isn't really necessary, just do a rebuild, bronze vavles, valve springs etc.
Rhemac /thread
Had work done by them but very impressed, timely, always keep in contact and excellent work. Maybe a bit more pricey but you get what you pay for. Best thing about them they won't oversell stuff just for you to spend more money there.
I also had a bad experience at Lewis Engines, piss poor attitude, terrible excuses and couldn't deliver when given AMPLE time. Stay way away imo. Ask Matty T about his headwork, see what he has to say
Rhemac /thread
What work did you have done Heslo?
Yeah i know Matty T very well, im good mates with him. And i heard his horror story with Lewis, lifters all needed to be reset.
What specs is your RB26? You do track work and it hasn't failed yet? Power output, engine specs etc?
I got my head fully rebuilt, ported, polished, etc. Had some Tomei Poncams fitted at the same time. Apart from that and the oil restrictor mod my 26 is internally standard,puts out 320awkw everyday @ 18psi and hasn't skipped a beat. I put a lot of that down to supporting mods like oil cooler and most importantly the tune. Touch wood I haven't had an issue yet but when I do eventually rebuild ill get Rhemac to do the bottom end also.
I've always had the motto spend a little more now to save later or the poor man pays twice. Going with this philosophy I've had a trouble free car modifying experience and a tonne less headaches. Sure it might cost a bit more but as I said earlier you get what you pay for. Can't afford it now? Wait! Youll kick yourself in the head later down the track when something does go wrong
Anyone got more information on James from Nisspeed? Does he do his own machining? Head porting?
YES IM PRETTY SURE HE DOES ALL HIS OWN MACHING AND ALSO MANY PERFORMANCE WORKSHOPS USE HIM FOR THIS REASON
HE DID ALL THE MACHING FOR MY ENGINE THEN PETER HALL ASSEMBLED IT
Yeah good point, hence why i'm getting a good builder to do it. Not like an average one like Lewis.
Do you remember exactly what work he had done to your head, cam specs, lifters, retainers done? Valve guides/seats etc? Oh and if you dont mind me asking, what did that sort of end up costing you?
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
