  • Replies 186
i think chubbs or cassbo posted this once.. i meant to do it in my intro-to-texi thread but forgot.. over and over. next time i see my liner is sunday though, so can't take pics before! arg
:P
That was a long next day :D
Any who, I took some pics as evil_weevil's ones have stopped working. Figure I might also do a bit of instruction while I'm at it.
Step 1.
Go to your local Autobarn / Supercheap / Repco / where ever. Take a look at what fire extinguishers they have. You are looking for 3 things
1. Over 0.9 kgs
2. AS1841.5 sticker
3. Pressure still in the "green"
4. Comes with a bracket.
Here are some pics of what I mean.
I bought my extinguisher for around $30 so I imagine that yours will cost a similar amount.
Step 2.
Pull the extinguisher out of the box and separate the bracket from the extinguisher.
Step 3.
Drill the mounting hole furthest from the bracket's latch out to at least 8mm. I drilled mine out to 9mm to give me some margin to play with when I finally mount it.
EDIT
Be careful when drilling as the drill can grab the thin metal of the bracket and force it out of your hands, usually giving a good gouge in the process. Use a vice or stand on the bracket like I did lol
Step 4.
Undo the bolt that holds down the passenger side of the rear seat.
Step 5.
Bolt bracket to rear seat mounting point.
Step 6.
Put extinguisher into bracket
Step 7.
Rip skids
Ian,
All good to turn up whenever you want through the day, and taking photos from the sidelines is fine. We have the photographers that can move about the place, and get closer shots; with their gear, we offer the service for people who want professional-type photos of their cars; they're frigging good at what they do :) I don't think you'd annoy anyone taking your own pics from the sides.
If you want to actually be a passenger in a car, you'll need ankle to wrist clothing, a helmet, and sign a short waiver that says you understand the risks of motorsports. Having said that though... It's a wide open pad with no trees or banks or anything :)
that being said, make sure you bring some church change on the day incase you feel like a feed/drink as theirs no atm's around the joint..
Thats one way to look at it, the other way is this; There is only one other location we could use for this in the whole of Sydney, it's overpriced and small. Where we go, there is a great relationship between club and venue, screamer pipes and therefore noise complaints from residents wouldnt help that cause and given this venue is booked every day of the year they dont need SAU's business so we do everything we can to not be a problem to deal with for venue management.
If it didnt have to be that way, i'd be all for it
if there still space u can enter long.
im buying one already with bracket from another member and im gonan fit it on the day.
There is a Super Cheap on richmond road blacktown (if yu get off the M4 at Blacktown reserviour road exit you'll drive past it)
There is a Super Cheap in Bella Vista Homemaker Center old windsor rd. (If you get off the M2 at seven hills you'll drive past it)
Guest
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
