hey guys rebuilding my bottem end after oil pump failure i already have a custom oil drain from back of head back down to sump
my question is do i really need higher volume sump if im making about 500 bhp i currently have stock sump .... and also should i change harmonic balencer and put after market one if so
what brand /model no. ??
https://www.sau.com.au/forums/topic/365969-gtr-89-32-build/
If going with a higher flowing pump then yes you need a bigger capacity sump, head restrictors etc (replacing with a R33 crank for the long oil drive would be recommended). read the oil control thread in it's entirety.. as for head oil drains, as far as their function.. the general consensus is they don't really work.
I wouldn't risk using that balancer again if there were a oil pump failure.
https://www.sau.com.au/forums/topic/365969-gtr-89-32-build/#findComment-5839361
Ok I already have restrictor s etc but not the sump do u recommend me changing sump ? Where is good place to get on if so
What is a good brand/model of harmonic balencer ? To replace standard one with ? And where could I source a 33 crank from ? Would itbe cheaper to go collar and change harmonic bal ?
https://www.sau.com.au/forums/topic/365969-gtr-89-32-build/#findComment-5839438
Try Justjap for the R33 crank, from memory they arent that expensive.
As for the sump, from my reading I would retain the factory item. There doesnt seem to be much move towards aftermarket sumps in a basic sort of setup.
GL
https://www.sau.com.au/forums/topic/365969-gtr-89-32-build/#findComment-5839635
it's as simple as this really. factory pump factory sump. aftermarket pump? aftermarket sump. a high flowing pump will empty your stock sump in a matter of seconds. literally. and with much less oil flowing back down it doesn't take long for the sump to run dry.
so if you want to run a jun pump, you need to get an enlarged and baffled sump. I've had no problems with trust sumps on 2 of my GTRs and the hi-octane sumps seem to work very well too. I'd buy one of those.
as far as balancer goes I'd either spend a little and buy an N1 balancer, or go for top of the line which is ATI.
https://www.sau.com.au/forums/topic/365969-gtr-89-32-build/#findComment-5840477
I think he's right!
https://www.sau.com.au/forums/topic/365969-gtr-89-32-build/#findComment-5840704
