hey guys rebuilding my bottem end after oil pump failure i already have a custom oil drain from back of head back down to sump
my question is do i really need higher volume sump if im making about 500 bhp i currently have stock sump .... and also should i change harmonic balencer and put after market one if so
what brand /model no. ??
https://www.sau.com.au/forums/topic/365969-gtr-89-32-build/
If going with a higher flowing pump then yes you need a bigger capacity sump, head restrictors etc (replacing with a R33 crank for the long oil drive would be recommended). read the oil control thread in it's entirety.. as for head oil drains, as far as their function.. the general consensus is they don't really work.
I wouldn't risk using that balancer again if there were a oil pump failure.
https://www.sau.com.au/forums/topic/365969-gtr-89-32-build/#findComment-5839361
Ok I already have restrictor s etc but not the sump do u recommend me changing sump ? Where is good place to get on if so
What is a good brand/model of harmonic balencer ? To replace standard one with ? And where could I source a 33 crank from ? Would itbe cheaper to go collar and change harmonic bal ?
https://www.sau.com.au/forums/topic/365969-gtr-89-32-build/#findComment-5839438
Try Justjap for the R33 crank, from memory they arent that expensive.
As for the sump, from my reading I would retain the factory item. There doesnt seem to be much move towards aftermarket sumps in a basic sort of setup.
GL
https://www.sau.com.au/forums/topic/365969-gtr-89-32-build/#findComment-5839635
it's as simple as this really. factory pump factory sump. aftermarket pump? aftermarket sump. a high flowing pump will empty your stock sump in a matter of seconds. literally. and with much less oil flowing back down it doesn't take long for the sump to run dry.
so if you want to run a jun pump, you need to get an enlarged and baffled sump. I've had no problems with trust sumps on 2 of my GTRs and the hi-octane sumps seem to work very well too. I'd buy one of those.
as far as balancer goes I'd either spend a little and buy an N1 balancer, or go for top of the line which is ATI.
https://www.sau.com.au/forums/topic/365969-gtr-89-32-build/#findComment-5840477
I think he's right!
https://www.sau.com.au/forums/topic/365969-gtr-89-32-build/#findComment-5840704
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
