  • Replies 48
The good thing is that he doesn't abuse people when they are wrong; rather, he points out their mistakes and goes about trying to help those people correct them.
I'm visit quite a few (car and non-car related) forums, and it's people like Sydneykid who are respected.
Gary gets my thumbs up. Thanks Mate.
I may even be considering a new career that I had never really been considered if things work out and I get to the Claude Rouelle seminar and workshop.
Although this sounds a little like an obituary.."god forbid" I'll throw in my 2.2cents inc GST.
Hi Bass Junky, You Said
"I would like to start a thread"
I have tested this method using a biometric actuating meta-data analyser, and have come up with following formula..
URGENT THREADS: Use 49.1% Methanol and 50.9% Spit
NON URGENT THREADS: 16.6% Spit 83.4% Vic Bitter, this is only if you cant remember the thread you were looking for, the technical term is also know as - Being Blotto -
(I would recommend storing a 1ltr bottle of spit connected to your PC via USB/Firewire, and attach a waterspray kit similar to that from Autospeed)
"To appreciate the acknowledge, guideance and wisdom that SydneyKid bestows opon us on a daily basis."
We use a similar theory for track racing, when we are loosing I run around the track bestowing my appreciation, acknowledgement, guidance and wisdom to all opposing competitors, by using a few formula's I created:
A= Grab the biggest mofo mirror you can find, aim it at the sun & point it in their eyes.
this has proved to work effectively, in the case this fails, we use alternative plans of attack.
B= Dump some oil in their path (just make sure your driver knows were you dumped it.)
C= One of crew dresses up as a marshall and waves the black flag
D= Cut across the track and ram the crap out of the other competitors until your in first place.
Hi MIC33R, You Said
"yep, without SK, I wouldn't know half as much as I now do about Skylines or even cars in general."
:( I'd like to start with the reason why you didn't know that much. I have pretty good success using this formula to determine the reasons;
Brain in lbs per minute = diameter of cells in mm X knowledge correction factor
So let's apply it to you;
300kw @ the brain = 480 brain power
480 brain power = 44 lbs of airflow = 44 mm of brain
Now if you want to run 19 psi of air through your mouth, then that's means you'll need to read that amount of my threads.
But we need to apply the brain boost correction method....
My experience indicates that to get 300kw @ the brain, out of a newB sau member you would need to run around 1.5 bar (22psi). So using the formula...
44 / 22 X 19 = 88mm of brain. In other words, you're only half way there.
Summing up, I think you guys have a numbers of problems, mainly your mouths are to small to soak up the grog and your fat % per capacity intake is too much, So you guys get Blotto on the smell of grog. To bypass this I would recommend springing your "mouth" using a 2bar mouthgate & attach an non returning blow off valve through the anal passage.
Hope that makes sense.
Lastly this message is dedicated to SK, thanks to you and many on SAU for your contributions.
__________________
I pretend, I don't own or work for a workshop
But I do know everything
lol, Gary is definately an asset!
But so are others... Steve/B-Man for being sorta guinea cops at some stages.
And doughboy and rev, they got some brain power there too!
Maybe dedicate it to ALL the people who are very knowledge filled :(
It does make for good conversations at times with the opinions of different people around here. And different expiriances etc,
Sure gets some informative debate going.
Gary's an ace. everytime i send him a PM, it would come flooding back with answers/comments and great advice.
its rare to find someone like him who is so readily to share his knowledge.
kudos to Gary again.
btw - is he reading this or is he too busying helping someone out again? :(
glenn
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
