every one has diff ideas on safe boost for a rb25 det neo :thumbsup:
my car mods are
the HKS gt-rs turbo kit
steel head gasket
head re-grind
full top end stud kit
hks timeing belt
pro cool intercooler
hks pod filter
440 fuel pump
full engine flush
new belts all around
hurricane custom 3inch sports exhaust ( cat and cannon )
after market radiator
split fire coil packs
hks elec boost controller
if i remember the other mods ill post
but im lookn at running about 15 psi on high and maybe 12 low waiting too see what the lowest the actour can handle
any help would be nice about this subject ((( or should i just run like 13 daily)) :unsure:
anyone whith this kit let me know what ur running and mods
Edited by Addicted2BoostR34
https://www.sau.com.au/forums/topic/366032-rb25-det-neo-safe-boost-presure/
The safe boost level that you are probably referring to, is if you have standard turbo....
After that is replaced with after-market turbo(steel wheels) the problem is now safe power level for engine output (kw).
May as well tune & run 20psi(or whatever the highest boost efficiency range is) , then use your right foot to achieve desired boost.
Edited by Shazza24
Boost pressure has nothing to do with "safe limits" on an engine.
10psi from a T28 is a lot different to 10psi from a T88.
As has been said, the only reason people refer to safe limits of boost pressure is on the stock turbo.
Your HKS actuator on the GTRS is a 1bar item so the minimum it will run is 1bar. They run out of puff at around 19-22psi dependent on engine.
But +1 on what ECU are you running? Please don't say stock.
stock ecu pinch.gif as im still not sure wat one to get my tuner would like me to get the vipec ecu.. but i like the Fcons with hand controller :pirate:
maybe even a nistune ?:S
as for fuel pump i ment the 040 in tank fuel pump
the 440 is the inline version
injectors are stock as im going to do them at the same time as the ecu
my plan was to get the gt-rs turbo on run it at min bar ..
get the head cleaned up
upgrade the pump
timeing belt exc
get some forged items in her belly :) do supporting things water / oil pump then once thats all done lookn into tuneing and injectors 2 match
i drive this car f*k all its a long term thing for me
the 040 pump will be fine for the gtrs, the 044 is the external pump your thinking of...
the vipec ecu seems good from all accounts and so is the nistune but the Fcon is harder to find a tuner for Ive heard, if you want a hand controller go the powerFC, but at the end of the day get what your preferred tuner has the most experience with and recommends...
you say you have 'hurricane custom 3inch sports exhaust ( cat and cannon )' tell me you will have a 3 or 3.5" dump as well....
I wouldnt even worry about a pod filter just run the std airbox with a decent hiflow panel filter or an arc airbox... pods are ghey imo.
Im assuming you meant 'cooling pro intercooler'... yeah.? never heard of a pro cool one...
with injectors keep in mind that E85 is around more and more and to run it you need 30% more fuel flow, more power, less detonation more timing...
Yeah ECU first pretty much in all instances.
Without it, forget running more than 7-9psi as the ECU will simply have a fit, not to mention you need injectors.
Have you even read the "what mods to do first" thread?
The RB25 dyno sticky?
You'll soon notice if you read every GT-RS thread, what the minimum requirements are.
yer 3" turbo back
pod was on it wen i brought it was thinking a nice metal fab'd one
and it would be 'cooling pro intercooler' that was allready on it wen i got it too ...
vipec it is i need to sell my bike and it will be done !!!
(injectors will be done wen ecu gets done ) so i will prob drive it like twice after the turbo goes on
i hae tryed 2 look for posts about the vipec but the button wont let me look it wont even find skylines pinch.gif
If your tuner wants the Vipec then go for it. Fantastic ECU and you will not be dissapointed.
Don't worry about half the stuff you listed that you want to do. Get the injectors and ECU done first.
its all done once i sell bike ecu and injectors :)
YZF400 any1 keen :P
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
