This is more of an info post to people who may have had similar problems to me.
The problem was after an extremely heavy and sustained downpour of rain whilst driving about 500kms, and the rain pouring the whole time, all of a sudden at 2500rpm, the engine would not rev any higher. It appeared that the turbo wasn't kicking in. Drove the last 200kms home without a turbo only able to go 85km/h and unable to accelerate at rate which would normally kick the turbo in or the car would essentially "choke". Similar to when u redline and the engine stutters.
I took the car to Nissan servicing in North Melbourne and was told that there was an error code on the air regulator. It was apparently refurbished and worked ok, but would make a slight stutter at 2500 rpm's as the turbo kicked in.
2 weeks later another heavy downpour of rain and the same issue occurred. Went to Nissan servicing and they then "cleaned" the regulator.
1 month later same thing again. I finally had some time so cleaned the air filter and air flow meter just with air compressor. Temporarily fixed problem.
2 weeks later another downpour and same issue again. I again cleaned the air filter and airflow meter, this time with WD40 in the air flow meter. Next day took apart the AAC (the bit with the idle screw in it). It was completely caked black inside. Cleaned this with WD40 and cotton buds. Put everything back together and the car now perfectly idles, no stuttering at 2500rpms and smooth acceleration.
My question and theory is that with the heavy rain, mist was getting thrown up under the car, getting through the pod filter, clogging the air flow meter causing a short, and also making the AAC spring and piston unworkable. I have no idea what part nissan servicing actually "refurbished" because it definatley wasn't anything i cleaned in the last few days.
https://www.sau.com.au/forums/topic/366073-air-regulator-r33/
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
