This is more of an info post to people who may have had similar problems to me.
The problem was after an extremely heavy and sustained downpour of rain whilst driving about 500kms, and the rain pouring the whole time, all of a sudden at 2500rpm, the engine would not rev any higher. It appeared that the turbo wasn't kicking in. Drove the last 200kms home without a turbo only able to go 85km/h and unable to accelerate at rate which would normally kick the turbo in or the car would essentially "choke". Similar to when u redline and the engine stutters.
I took the car to Nissan servicing in North Melbourne and was told that there was an error code on the air regulator. It was apparently refurbished and worked ok, but would make a slight stutter at 2500 rpm's as the turbo kicked in.
2 weeks later another heavy downpour of rain and the same issue occurred. Went to Nissan servicing and they then "cleaned" the regulator.
1 month later same thing again. I finally had some time so cleaned the air filter and air flow meter just with air compressor. Temporarily fixed problem.
2 weeks later another downpour and same issue again. I again cleaned the air filter and airflow meter, this time with WD40 in the air flow meter. Next day took apart the AAC (the bit with the idle screw in it). It was completely caked black inside. Cleaned this with WD40 and cotton buds. Put everything back together and the car now perfectly idles, no stuttering at 2500rpms and smooth acceleration.
My question and theory is that with the heavy rain, mist was getting thrown up under the car, getting through the pod filter, clogging the air flow meter causing a short, and also making the AAC spring and piston unworkable. I have no idea what part nissan servicing actually "refurbished" because it definatley wasn't anything i cleaned in the last few days.
https://www.sau.com.au/forums/topic/366073-air-regulator-r33/
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
