now, the one near the washer bottle is actually on the chassis rail towards the bottom of the car
there are threaded holes there already, so we just drilled the hole on the ballast box a little bigger and that was it
did you purchase this xenon kit of someone or was it from the global premier site as im also interested in replacing bulbs which happens to be a series 2 as well. Also, does anyone know how to change the bulbs as one of mine is blown.
cheers
the kit was purchased from a mate, hence the cheap price :)
Unfortunately I'm the worlds crappiest photographer, and the photo has come out fairly blurry.
You can see the brightness of the xenons in the picture. I will try to get some better pictures during the week.
Sorry its so blurry.
Jason.
the kit was purchased from a mate, hence the cheap price :D
Jason.
My eyes, my eyes! Urgh!
/me gives uneekwahn a camera stand.
LW.
Do you know if these auto electricians care much about the legalities of Xenon conversions given that ALL kits are technically illegal?
And can someone pass us a contact in Sydney?
T.
Apparently there is a dude up Newcastle way that will provide an engineers certificate for xenon modifications (assuming you set the up correctly, etc).
LW.
Can we see some of the front??? Isn't that the whole point of Xenons is that they look cool from the front??
No, the point is the provide better light. As a side benefit, most people think they also look good (although you should only use 4100k bulbs which don't have much of a blue hue).
LW.
these globes are pretty much white. no blue hue whatsoever.
i will get some more photos, but don't have a very decent digital camera (no zoom and flash stays on permanently) will see if I can get a mates nice 5 megapixel to take some shots
yeah, I went out with joe (pva_glue) for 3 and a half hours last night taking good photos of the car.. I'll have some in a gallery in the next couple of days :)
yeah, drive behind me, as long as someone gives me a radar detector :)
Errrrr... That's not exactly an accurate portrayal of how bright your xenons are.
The thing with photography is that you have such a great deal of control of exposure through shutter time.
Joe could have set that frame to expose for 10 minutes and you'll get basically a pure white top half of the photo.
Take a look at the rear taillights. They are a good indication of how overexposed that photo is if you are trying to get an accurate feel of what those headlights look like.
merli, you are correct, he did set the exposure time to 30 seconds.
they are quite bright and I will get some more pictures, with normal exposure time. unfortunately its hard to get good photos of the lights without exposing for a longer period of time.
Very true... Shouldn't be too hard with a digital camera though...
Nice headlights btw... Sorry I didn't see this thread earlier, as I had an aftermarket Xenon kit in my old Series 2 GTS-t with no problems with heat inside the enclosure.
I love xenons :(
i think we were just over zealous with the over-exposure due to its cool effect :(
going through the shots, nearly all have long exposure times ;)
thanks for the reassurance about the heat inside the enclosure
I've had these on for about 3-4 weeks now, and they do rock. Could never go back :)
That offers still up for you to come over to take photos by the way :rant:
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
