after having a good look at my CP rings, i cant figure which is the right way up,
the top ring and the 3 oil rings have no marking and dont look any different either way up, although the secong ring, pictured above, does, it has N2 stamped into one side, and a not tacken out of it the other,
also i just broke one of my second rings, so now where can i by a new one, single set or hopefully not a full set, as with all engine builds funds are becoming tighter by the day
cheers
dan
https://www.sau.com.au/forums/topic/366230-cp-piston-rings/
The top ring can go either way, it is a barrel faced parallel ring from memory
The second ring is a scraper so the ring is placed in the bore the same way you have it pictured. Cutout facing downwards. N2/2N or whatever it says - you should be able to read that from the top.
I have a set lying around at home we were gonna bin. Brand new. What thickness are yours? or what part number ring set and bore size?
Failing that - Wiseco are the distributor for CP nowadays
https://www.sau.com.au/forums/topic/366230-cp-piston-rings/#findComment-5842613
