Carrera Car Wash
vrm
 Share
Washing your car
23 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I hate washing my own car. Two particular so I end up spending 3 hours getting every inch glistening... usually causing more damage then good in the process. Right now it looks like a rally car so have been meaning to get it washed... may take this up.
Try to wash my car every weekend, but if it is raining, I leave it till next week and hope it ain't raining.
Same.
I wash my car properly (takes over 2 hours) each weekend. If it gets dusty during the week then I'll wash it a further 1 - 2 times at the carwash. Gets dust off but no chance of getting grime off.. Those things may aswell spray compressed air instead of soap/water.
2 hours? What on earth are you guys doing? :O
I can have my whole car washed (exterior) in around 15mins, 20mins if im being slow. 10mins to dry, 15-20 if im talking or on the phone.
Interior isn't much more than a wiper over of the dash, doors etc.
A good body detail, with good wax etc = cut times down MASSIVELY. I can almost wash my car just off a high pressure hose because of it, and im talking full brown dirt thats been there for 3-4 days :)
I wash mine once every few weeks.... depends on the weather. I just take it to one of those do it yourself carlovers places...And I use the brush!! hahaha. It's not a show car I don't car about small imperfections. On my previous car I waxed and polished it by hand wax every now and then to keep the black shiny.. Wax helps alot with the finish.
wash my car whenever it needs it really.. maybe once every 2 weeks
im lazy lately and normally go down to the apple peel carwash and pay for was wax and interior
did it today :P
Takes me a while to set up. Gotta unpack high pressure washer, hoses and I'm constantly running inside to fill up more buckets of water etc.
Pre-soak - One bucket worth of suds to go over the whole car and loosen up the dirt
Pre-rinse - Rinse off a majority of dirt, so it doesn't scratch the paint when I wash it
Wash - Go over the whole car with microfiber. 2 buckets: 1 soap, 1 water, rinsing any dirt off the towel to prevent scratching/swirl marks
Wheel wash - Use the leftover soap on a different cloth to clean wheels, exhaust and inside guards (if they're visibly dirty from outside)
Rinse - High pressure rinse
Dry - Chamois or microfiber dry the whole car (except wheels) and have a bucket of water ready to rinse towel if I go over any dirty bits I missed while washing
I then use a disposable cloth (got 1000s due to mum's work) to dry/clean the wheels coz they tend to be the dirtiest, getting into all the little grooves. Occasionally then I will use 'Purple' wheel polish on the chrome lip if they're looking dull/oxidized.
Wax - (Although lately I've been lazy and used a pH neutral shampoo/wax (all in one type thing) which negates this step)
After that I'll gloss up the tyres with some tyre shine and that's the exterior done. Including the setup/packup all that can take me over an hour if I take my time. It works for me and results are flawless.
Edited by jezza boii
I do much the same thing as Jeremy, however wax maybe every 4-6 months. The paste wax I use lasts for a long time.
I'm starting to cut down the time I spend spongebathing it though...it's just too much, and a waste of time. Whilst it's nice to have a car flawless on every panel...unless you're standing closer than a metre away, you won't notice the difference between that sort of job and one you've spent half the time washing less thoroughly. That and, give it half an hour, you already have your first dirt mark again. More frequent washes done in half the time is where it's at.
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
