Hey everyone..
im appealing to all the gurus out there in the car security world.. After recovering my car the other day from being stolen its sorta been sitting around and only being started to move around..
Everything was working fine but last night the battery went dead and now when I disable the alarm/immobilser my power FC isnt getting any signal so the car will turn over but not fire as there is nothing to start the ignition..
After much faffing about looking at all the fuses and checking the PFC board for a short i pulled out the r34 GTT ecu pinout and started to look for voltage inputs and both pin 24 Ignition switch (IGN) signal and pin 20 ignition switch (start) signal are not getting voltages and hence not turning on.
Only thing left is perhaps the alarm which is a Mongoose M60s is not properly disabling itself.. (I have tried the manual overide also) Is there a way that i can remove the alarm just to test if its indeed the alarm causing the drama..
I have spoken to Daniel from carbon car audio who installed it a few yrs back but he was unable to talk. I will be giving him a call tomorrow to follow up but just wanted to ask a few more people in the time being for any other advice..
I hope all of that made sense as there is alot of info to put forward.
Thanks in advance for any help!
David
https://www.sau.com.au/forums/topic/366282-mongoose-m60s-drama/
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
