hey everyone,
looks like i have a water leak, i noticed it when my temp gauge started getting to 100 degree's on my drive home lol. Once the motor cooled down i checked my water level in the radiator which was very very low so anyway i looked under the car and noticed its dripping water somewhere on the back of the motor (still cant find it). its dripping onto the front pipe of the exhaust any ideas what it could be? maybe water pipe to the turbos? it looks like its coming from the turbo side of the engine.
any advice would be appreciated like always peeps :)
Regards,
Dom
https://www.sau.com.au/forums/topic/366295-r34-gtr-water-leak/
I jacked the car up and found the leak, looks like its one of the fittings on a hard line feeding from the turbo into the block, hopefully the flare hasn't split and the fitting only needs tightening... crossing my fingers it doesn't get worse on my to get it fixed..
i had a similar prob on my s15. was a water leak but couldnt see anything in the driveway so it would only leak when driving.
result: turbo water line - the s/s manifold expanded and contracted on heat/cool and cracked the hard line.
fix: swapped for braided water line
do you have aftermarket manifolds?
anyways, goodluck with the problem. hope it all goes smooth
I had this problem like a month ago. Im near guarantee its one of the two small hoses (bout 4cm in length) at the back of the motor. You have to take the plenum off to get to it.
Heat the car up and get a torch or shine down the back of the motor and have a look if you can see where the water is comming out. If its one of those small hoses, replace both. You will need new throttle body gaskets and a new aac valve gasket. also get some hose clamps instead of the shitty ones that are on the std hoses.
Also doenlowd the inlet manifold page from the service manual. Its a bitch of a job.
I have had the same lines fail on my car. It is possible to do them without the removal of the plenum.
I had as similar problem a few weeks back. Same drip location, but was a welsh plug right next to the turbo. Was a hard fix but sealed it with some aluminium cement until the motor comes out for a proper fix
Good luck hope its a easy fix
Finding leaks can be dam tricky sometimes. A leak thats up higher can convince you its actually leaking somewhere else in a difficult to repair spot.
I was convinced I had a hard line leak a few weeks ago too, till eventially the rubber hose that links the turbo coolant hard return lines back to the radiator top hose split and it became obvious where the leak was. I couldnt see it initially as the hose I am referring to is located under the air intake snorkel to the factory airbox.
The coolant leak was running from that hose, back along the pipe because the pipe is angled down towards the turbo.
I hope its an easy fix for you.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
