Hello
I have a PPG 6 speed dog box sitting here which has managed to split the stock getrag center plate. Not really a big problem but i only hear horror stories of these gearsets getting destroyed.
What info do you guys have on these boxes? I know it is possible to buy an billet centre plate but for almost £2000 its not worth it in my eyes considering the gearsets cost £7000 lol
What is common on them to break? I know dogs wear out but they do on all dog boxes so not fused.
I would like to know your thoughts on them as i don't believe the bad press they get over here in the uk.
Cheers
Jamie
https://www.sau.com.au/forums/topic/366316-ppg-6-speed-dog-box-r34-getrag/
basically the PPG boxes are pretty good but you have to keep up the maintenance. there have been some problems but most of the failures come with people who thought buying a big $$ gearset was as set and forget option. they need to be regularly pulled down, inspected and maintained (replace worn/suspect parts) to keep them running nicely. if you do that they can and do live a happy life.
as far as billet centre plate goes yes they are expensive. Didn't think they cost that much. maybe contact PPG direct in aus? cause 2000GBP is over $3000.
If the gearset really is 7000GBP + 2,000 for the center plate then it might be worth considering a hollinger. consider that to run the PPG you need to re-use your stock box and there are labour costs to assemble it all (maybe another 1,000GBP). That's now 10,000GBP ($15,000) plus your standard box. For about $20K (or just over these days) you can have a full sequential hollinger which is a full replacement gearbox (not a gearset). so you can sell your old box (maybe 2,000 or 3,000GBP - call it $4,000AUD). so if the hollinger is approx 13,000GBP minus say 2,000 for the sale of your stock getrag you are looking at only 11,000 change over for a brand new full sequential box which are far superior. Any geerset is limited in what it can do because it has to work with a number of stock parts (casing, centre plate, bearings etc). The hollinger is completely redesigned so has none of those limitations. Plus it comes fully built so you don't have to worry about it being assembled properly.
I would look into it if you are serious about your GTR. best bit is they are lighter and more compact too... :)
Cheers guys.
Yea i have contacted PPG and they want $2600AUD plus $150AUD shipping for their billet centre plate. I have been told i need to add 31% to that in taxes :(
The stock gear set comes in at $9900AUD so its an expensive piece of kit.
I build GTR gearboxes and have done my stock getrag about 4 times now due to cracking 3rd gear snycro all the time.
I know these kind of boxes need stripping down and inspecting to keep them in one peice but was wondering on how long there should be between inspections? A hard trackday will see it coming out if it survives at a guess? but using it on a road and drag strip it must last a little longer?
The box i have has done some dyno work , and about 6 drag runs and the dogs look worn already. :( It was big bhp r33 so to be expected.
Will it even last one drag day with say about 10 runs? lol
Cheers guys.
they should last longer than that. excessive dog wear can be due to too many slow shifts on the street. I'm sure you know the dogs are sacrificial anyway in that they are meant to wear as that style of engagement is pretty brutal and the corners get knocked off the dog teeth pretty quick with a few slightly off or slow shifts. you do need to shift fairly quickly and firmly. almost the complete opposite of a synchro box (but again i'm sure you already know this stuff).
I would say a first a pull down after ever track day or second track day would be a good idea. after that you'll get a feel for how things wear and how often you need to be pulling it down to service.
The price seems a bit harsh but I'm not sure how else you can get it. why is there 31% tax? I'm assuming that's local tax in england? you certainly shouldn't have to pay that tax to PPG, in fact it should be tax free (ie 10% less than the aussie local price).
I have been down that road, EDTI: I was not happy. I got the whole gear set, billet centre plate and everything else done to the gearbox and had nothing but 2 years of head ache, gearbox was pulled out of the car 6 times, then a law suit to get some money back... I got money eventually but I will personally never go there again...
If you want info on them just have a look on the forums... or google.... I went and bought a Holinger have had a great time since..
My advise is do the gear box up and get rid of it..
Cheers Dave
P.S mods I have got a legitimate story and other people need to know what happens when you try to do the right thing.. I would appreciate this not to be deleted.
yep agreed. and the biggest reason all the other box options are compromised is that they are designed to fit into the standard housing which has flaws of it's own. even once you buy all the new shafts, centre plates etc there is still factory parts in play and they cause dramas. it's good money after bad. buy the hollinger and never look back!
dave, I'll leave your post but have to edit it a tad inline with forum rules. sorry mate but it's the way it is. it's to protect the forum owner who is a private citizen and does get threatened with all types of lawsuits over forum content.
don't think holinger have an H-pattern GTR/skyline box. so yeah sequential is the go. the only reason you wouldn't go sequential is if there was some class rules you needed to meet. cost is around $20K. need a few things:
new clutch (to match the bigger input shaft. hollinger can make a box with standard nissan type spline but don't do it, get the better spline and replace clutch to suit it)
new front drive shaft
new rear shaft
not sure which transfer case your 34 has but you need to use a 32/33 transfer case with the hollinger
new mount
that's about it off the top of my head.
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I elongate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for?   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
