If you can't afford insurance, you can't afford the car IMO. Police should be pulling over tow trucks at night time...running checks on the cars to make sure the towie has the keys etc.
  • Replies 98
Posted Images
Car found, being chased by chopper. He rammed a police van so they will definitely want him now. I was driving around in the mrs line trying to find him and got pulled over by 3 cops. Hopefully they get him before he writes my car off.
I actually found out who he is and his addy. If your in the west don't drive your line tonight
Also I agree with tge whole can't afford insurance can't afford the car thing, but I've owned the car for 3 years no problems, just in the last 2 months have been a bit poor until work picks up
Edited by topher_
so thats why the cops were out! there was a cop driving slowly on sunshine ave shining his torch into the back of peoples houses. another cop car on my street (lady nelson way), he pulled out of my drive way as i was approaching so got me suss so i kept driving behind the cop to see what the cops were up to and then i saw cops with sniffer dogs two doors down from my house.
someone i know said they got pulled over by the cops and were asked if they saw a white skyline. they said no, but they saw it fying by with no lights on not long before they were asked. sniffer dogs wouldnt do much in getting a car. im assuming that they located the car and the guy has started hiding/running or he did something else than ramming a police can. i just find it hard to believe that they managed to loose him, especially if he rammed a cop car.
anyway, hope they find your car, if you wanna 'work some things out' with the guy, im sure there are a few people here that would be willing to come down n give you a hand. out of curiosity, why did the police tell you who he is / where he lives. do you know the guy?
Cops didn't tell me who he was I figured it out by myself, asking mates etc. dick heads like that always open their mouth. Anyway he got away but they know who he is too, have his prints etc.
My info was a bit wrong. The guy who lives near me spotted out the car to his mate who lives in keilor downs stole it but they were in it together.
Chick at my mums work is married to a detective at sunshine apparently and my car has a fair bit of damage apparently. Haven't got an official call from the police yet, but I'll have a shower and breakfast then give them a call. Hopefully it's not too badly damaged
well he was in a 300kw gtr as opposed to a holden omega..
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
