  • Replies 98
Posted Images
Shit...sorry it had to end like this buddy. At least you got something back, which is better than most stolen uninsured cases turn out. I'm no panel expert, but it looks like about 7-8k worth of damage to fix, assuming it's just that side of the car and the chassis isn't bent / the pillars are straight. Can't tell if the A pillar looks alright? Then there's the mechanical side of things I guess...they wouldn't have been too kind on the engine/driveline.
Seriously what goes through peoples heads doing shit like this, "Yeah I'm gonna steal someones nice car, get in a chase, smash the car and cop cars and end up in worse shit than if I sat at home playing with myself"
Edit: Did they steal that 33 as well?
Edited by miguelegant
Didn't ask, probably not. Cops said heaps of skylines have been getting pinched around here, but then again they said the guy they suspect steals skylines all the time, so who knows :|
Went for a drive and the shop was a milk bar
posted that on gf's account lol
Used your credit card?
Debit master card, passed the info to the cops already. Went in there and bought a drink, heaps of cameras there.
Doesn't seem to be a professional job to me...Pros wouldn't be driving the car around days after stealing it...They'd more than likely have it in a garage and stripped for parts...
Like I said, you'd easily get $3k for the rims alone...
we need to do a set up! set up someones car to get stolen and like 100 sau members hide in the bushes then run out of the bushes screaming with poles!
Edited by bluejeans
    • You're not wrong but 5W30 at 100C is like 10 cSt vs 25 cSt for 10W60. If we think in terms of viscosity margin 10W60 will probably still be ok at 130C but 5W30 is probably too little. It's absolutely shocking how hot the oil gets in something like a stock FL5 from only ~3 minutes of use on the Nordschleife. I would not risk taking a car like that to anything remotely intense without a ton of work done for cooling. Heat shielding on the manifold/turbo/downpipe, oil coolers, etc.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
