Hi guys,
I have a S1 R33gtst thats recently developed a loss of power problem.
About a month ago it developed a misfire so I did a full service and replaced the coilpacks with splitfires as well as the spark plugs and it was driving like new again. Last night however my problems have returned it feels sluggish and struggling to come onto boost. There is no misfire now but it just has no guts. If i try and put my foot down it eventually comes onto boost and can reach redline but it takes a while.
Best way to desrcribe it is as I am speeding up from say 2nd to 3rd with the boost on vacuum (ie 25-30% throttle) it sounds like it is on full boost and as i change gears the blow off valve lets go as if i am on full boost. Kinda feels like something is being restricted. I am thinking it may be a leak in my piping or dirty air flow meter but would appreciate any help pinpointing the problem. Havnt seen any smoke out the exhaust so i dont think the turbo has let go, but I should mention that it makes a bit of a rattle when on boost.
I am only running 10psi on stock turbo with fmic, avcr boost controller, bosch 040 fuel pump, emanage ultimate ecu.
Any help would be much appreciated!
https://www.sau.com.au/forums/topic/366349-help-loss-of-power-r33gtst/
i dont know avcr's but do they give a constant display of boost pressure (like the greddy profec's do)
if so what are the numbers you are reading?
also turbo's dont usually 'rattle' when on boost... many people have complained of a brief high pitched squeek but never a rattle...
Yeh they do, and the reading matches my other boost gauge aswel so i dont think its a problem there. Its set to 10psi and it will eventually boost up that far but it takes its time getting there. Been installed for 6 months with no probs.
And i know what you mean about the turbo noise a mate of mine has had a few let go on him and its not the same noise at all. This one doesnt sound quite that serious though its sounded like that for almost a year now with no problems.
I cant think of why it would run shit, be fixed and run great for two weeks then in one day deteriorate back to how it used to be :S
ok 2 things, the rattle on boost may be a sign that there is a damaged exhaust manifold gasket or broken manifold studs, or possibly the turbo has come loose on the manifold.
the boost issue could be caused by the leaking manifold, but it also sounds like an issue i had with a turbosmart dual stage manual boost controller. what was happening in my case was that there was a T piece with a 1 way valve in it. 1 hose went to the intercooler, another to the wastegate and the 3rd to the controller. the issue was that there was also a tiny bleed hole in the T piece. long story short, the bleed hole was blocked so when you lifted off the wastegate was still being held open by the pressure between the 1 way valve and the wastegate. this meant that when you changed gears the next gear had no acceleration and took for ever to build boost.
i would be more inclined to say you have an exhaust leak or possibly an intake leak. if it was an intake leak then the car should be running rich though and it may break down (misfire) when you floor it.
Thanks, I had a look today and have noticed that it is very oily underneath where the rocker cover is attached on the exhaust side, could this be a further indication that it is the exhaust manifold gasket or just a bad seal around the rocker cover? Had a quick check of all intake piping and couldnt find any obvious leaks but i will need to do this properly over the weekend and take a good look at the exhaust manifold gasket. no misfire to speak of even at 100% throttle since the splitfires went in though and no excess fuel consumption or blackening of my rear bumper from the exhaust so i am inclined to think its not running excessively rich so not an intake leak from what you are saying?and the cat is under 6 months old high flow so i doubt it is the problem
Edited by sam_c
the oil will just be from the rocker covers. extremely common problem.
when you check the manifold, just look and see if all 16 manifold studs are there (2 per cylinder). it's common for a few of them to break off, thus resulting in a leak as well as a gasket rattle.
Hey,
im having a similar problem, it feels like shes not as punchy as she was when i baught her about 4 weeks ago.
im thinking it could be a piping leak or some sort of leak, its a stock s1 R33 gtst everything running stock atm (7 p.s.i).
i am getting a few misfires but not under power, only when i release the throttle (i suspect that could be a F'd O2 sensor because im getting terrible fuel efficiency as well)
my boost gauge reads like it did when i baught it but it just feels sluggish when the gauge is telling me its at full boost.
what should i check first?
cheers guys
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
