RB20DET S13 manual 1990 model
Engine
- stock RB20DET from an R32
- exedy HD clutch replaced ~5000kms ago
- aluminium radiator
- twin 12" thermos with thermostat and thermostat override switch
- 3 inch cat back
- bosch 040 fuel pump
- blitz pod filter
- gktech overflow
- stock SMIC
- turbo timer
NEVER BOOSTED ABOVE FACTORY BOOST!
Interior
- complete tan interior
- boost and water temp gauge, may throw in oil temp and oil pressure gauge depending on price offered
- HUD
- Greddy gearknob
- sunroof and all electrics working
Exterior
- stock panels
- sunroof
- all lights working
Footwork
- R32 gtst 4 pot front brakes
- stock suspension
- unknown 17" antitheft rims with 80% goodyear f1 eagles 225/45 up front, 80% neuton NT5000 235/45 rear
Comments
- damage to rear right quarter panel, nothing too major
- rust near sunroof, rear quarter panel and driver side door jam
- cracked windscreen
- needs new no.4 coilpack, can be replaced depending on price offered
- oil/filter has been changed with mobil 1 and copper NGK spark plugs, only driven literally 2kms after service
- car pulls hard, will beat most stock r32's, nice rb20 exhaust note
- always garaged since purchase
- engineered by Williams Automotive Engineers in 2004, comes with all papers and documents
- car has been off the road since 2006. car is currently unregistered, is not written off and has no finance.
selling the car because i need money to finish off my ae86.
inspections more than welcome
asking price is $4500 negotiable, hit me up with offers however lowballers will be ignored. if it doesnt get a decent price then i'll be keeping the car for track use.
contact: 0421 152 048 located melbourne northern suburbs
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
