  • Replies 156
good work Nick! Your exposure is perfect, got in all the lights but haven't flared enough to obscure the details!
I've finally had time to look at my shots. here's a couple from the same night...
nice shot too Eclipse. Crop/clone that car from the far right and that shot is WINNING!!!
my first for the month...
i'd like to reshoot something similar to this with a more approriate lens.
^ LOL!!!!!
did the light painting shot of my car turn out ok?? Nice shot of harrys pie :)
John - Much better with that picture. Looks like a bit of distortion at the bottom. What do you think?
Rest Here:
http://sidd-rishi.com.au/blog/1/photoshoot-with-audrey-at-north-sydney/
Nice that looks great :) good work!!
Thanks guys!
Very little PP work - straightened the horizon, changed the white balance to Flouro lighting (because it looked the most natural), and that's about it!
Guess what I did? >_< Being the dumb-ass that I am and in a rush to do things, I accidentally deleted all the images we took at Mrs Macquarie's Chair... :pwned:
Nothing fantastic from me, but its a start.
Crappy light painting attempt on my mates work ute. We'll be doing a shoot on his Cefiro soon, but I'll find a better light source other then my iPhone :P
I have half a second the set the camera up to snap this plane flying over. Pretty much fluked it, and got this:
And I think this is self explanitory? Haha:
wow Sidd! love the direction your heading with the portraits dude. only thing i could fault about the second one is her standing directly in middle of the frame, but thats just me, its a great shot.
love seeing the pics in this thread!
Edited by Jay019
Matt would of just converted it to B&W i'm pretty sure and because there was mostly white and black tones that's how it turned out. Might of painted the sky a bit blacker, depends how long the exposure was. If you shoot the same thing and convert it to a strong B&W, you'll be a maestro too!!
Please Note: Could be wrong!
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
