  • Replies 156
good work Nick! Your exposure is perfect, got in all the lights but haven't flared enough to obscure the details!
I've finally had time to look at my shots. here's a couple from the same night...
nice shot too Eclipse. Crop/clone that car from the far right and that shot is WINNING!!!
my first for the month...
i'd like to reshoot something similar to this with a more approriate lens.
^ LOL!!!!!
did the light painting shot of my car turn out ok?? Nice shot of harrys pie :)
John - Much better with that picture. Looks like a bit of distortion at the bottom. What do you think?
Rest Here:
http://sidd-rishi.com.au/blog/1/photoshoot-with-audrey-at-north-sydney/
Nice that looks great :) good work!!
Thanks guys!
Very little PP work - straightened the horizon, changed the white balance to Flouro lighting (because it looked the most natural), and that's about it!
Guess what I did? >_< Being the dumb-ass that I am and in a rush to do things, I accidentally deleted all the images we took at Mrs Macquarie's Chair... :pwned:
Nothing fantastic from me, but its a start.
Crappy light painting attempt on my mates work ute. We'll be doing a shoot on his Cefiro soon, but I'll find a better light source other then my iPhone :P
I have half a second the set the camera up to snap this plane flying over. Pretty much fluked it, and got this:
And I think this is self explanitory? Haha:
wow Sidd! love the direction your heading with the portraits dude. only thing i could fault about the second one is her standing directly in middle of the frame, but thats just me, its a great shot.
love seeing the pics in this thread!
Edited by Jay019
Matt would of just converted it to B&W i'm pretty sure and because there was mostly white and black tones that's how it turned out. Might of painted the sky a bit blacker, depends how long the exposure was. If you shoot the same thing and convert it to a strong B&W, you'll be a maestro too!!
Please Note: Could be wrong!
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
