White R34 GT-t with Nismo wing mounts? That's all I saw out of the window at work haha. On Abernethy road.
And a silver V35, chick driving. Don't know the suburb though, not far from Morley/Inglewood.
grey r34 gt(t?) sedan driving up my street tonight,u-turn,wheelspin,then off down the road.(and they call r33's boats!!).
nice black r34 gtt coupe at bunnings balcatta yesty.sweet nismo rims.to the wanker in the skyline who parked next to him a few days ago and left with his gen nismo centre caps,mate that's just not right.denim,we're lookin out for ya.:thumbsup:
Black R34 GTT turning off Joondalup drive.....into Shenton Av....bout 5 pm - ish.....very clean.....sounded good :)
Saw it out of the corner of my eye..so didnt get a chance to see anything in detail
Edited by jez NF
Just spotted R XXXII at the Whitfords shops car park.
I'm sure they are on here but I can't find them
Waves exchanged.
One clean looking 32!
That would've been me, and yours looked very nice as well.
I saw like 3 other 32's (parked) down there while trying to find a spot, anyone else from here there tonight?
(would've been about 8ish I think?)
Edited by are bee's
Spotted a white stag tonight turning onto Tonkin hwy...
Also spotted the nicest V35 coupe I ever saw. White with satin black wrapped roof...
Black work varianza T1S
Is he on these forums???
Edit - in northbridge just outside nicks lane Chinatown..
I came buckets.
Edited by Mr Eps
spotted some guy wearing a SAUWA Jumper at Curtin Uni around 1ish 2pm Yesterday, was picking up the missus and saw you walking, was about to drive on the path behind you and then say hi but them curbs are hideous.. jk
white 33 gtst parked across from holden dealership. i think it was charles st? was near northbridge. 1pm
silver 34 albany hwy vic park 2pm had L plates up
silver v35 in front of me down canning hwy from como-fwy exit 230pm
wine red 33 on freeway near safety bay rd northbound.mature aged gent driving? 3pm
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
