Spotted Mk2 ! Do Not Post Licence Plate Details
10 4
Spotted a white 33 yesterday, around midnight on wanneroo road near Ashby.
Spotted silver GTR outside mindarie Maccas getting fuel from Peak (hope not!) stock as a rock and silver looked really nice waves and hellos were exchanged.
Around 10-11am?
Spotted a gunmetal grey 32 gtst, around the marmion area not sure of street, around 11:30am was very clean and young woman driving it was pretty attractive too :) almost didn't wave in time hope you saw it haha :)
Then saw black 33 on Alexander drive around 5:30pm
I also saw a 33 on Roe highway this morning which had a sauwa sticker in the bottom-middle of his rear windscreen.
Dont remember the colour, nor actual type of 33.
Spotted yesterday just before 6pm;
White 33 GTST with GTR wing and white multispoke rims cutting off traffic from the lights and tank slapping across the Hepburn/Alexander intersection.
If you are on here, you're a f*****g douche.
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
