Good to have you back Chris.
Spotted white R34 gtt, parked at Dianella shops and leaves it there all day..
Pretty game.
Edited by Hardcore Princess
Yesterday
White 33 Gtst on kenwick link lights turning right onto Roe about 550. had SAUWA sticker on drivers side rear quarter window.
White Stagea(not sure what model) coming onto Albany hwy near kenwick link and was behind me up past Carousel. had 2 small spotties/driving lights, one on each side of the grill. 6pm
Today
light purple 34 4 door on the freeway just north of the city. had a yellow sticker. about 10ish
GMG 32 GTR going south down Albany hwy about 1030 near brian gardiners
white 32 GTR with black rims parked in carpark near JB Hifi/pet magic area albany hwy/kenwick link intersection 1230ish
white 33 gtst with black wing on kenwick link at roe hwy lights about 1pm
Spotted black 34 with SAUWA sticker on marmion ave outside Mindarie mcdobalds ended up going same way through the roundabout.
Next time don't be a dickhead go and pull infront of an old land cruiser last second so we can both sit at the lights I'm not interested in drag races fair enough if you want to say hi but you need to be aware of your surroundings and not be a danger to anyone else on the road. Was clear he wash going to be able to stop in time and you ended up getting pushed through the lights.
spotted bunch of nerds walking around curtin last night, in full chain mail and armour with huge double handed steel swords, some with shields etc.
then watched them on security cameras attacking each other in the park. wtf! apparently its some real life version of dungeons and dragons.
Edited by Char
ROFL that's awesome!
PS: It's called live-action role playing
Edited by Dingus
Was down in Warnbro yesterday dropping bub off to her grandparent's for the weekend, and spotted around ~1:30:
White S2 Stagea near Shell/Chicken Treat
Laura (ICULOOKN), Yellow S2 Stagea RS4S with Vic plates still, on Safety Bay Rd
White Stagea with 260RS kit just off Safety Bay Rd
Real yellow 34R on Mounts Bay Rd around 12:30pm on Friday. Bsb 34R on Manning Rd briefly today around 12pm then 5 mins later a silver 33R heading east on High Rd.
Lastly a black 34 Gt-T turning right on High Rd off Willeri around 1pm. Had black rims and SAUWA sticker on rear window.
Oh and drove next to bsb RS4 Stagea yesterday on Rockingham Rd in Naval Base. Gave the wave but was snobbed off. Was in my Stag as well-gotta love the WA friendliness!!
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
