Spotted at about 1:10pm, silver R33 on Ocean Reef Road with GTR wing; didn't get a good enough look to see if it was a GTR or a GTST. Had a SAUWA sticker in the right rear-quarter window action-smiley-069.gif
In Moore River over the long weekend spotted a very clean/showroom quality Silver 32 GTR cruising around near the roundabout with the binoculars man on the Friday. (early arvo I think)
Over the rest of the weekend i saw a Maroon S1 R33 a few times out 'n about, a Silver 34 four door parked out front of a house about 150m up from mine and a Maroon 32R driving around the above mentioned roundabout.
Spotted silver 33 with SAUWA sticker on passenger quarter window on ocean reef at marmion/ocean reef lights, waved but might not of seen it though you revved the engine high so I assumed you were saying hi, shoulda dipped the lights. :)
Edit: around 7pm ish
Edited by MACR34
Spotted two gunmetal grey 32 GTRs one was at roundabout on marmion just after burns beach (heading north) and the other at ocean Rees road and marmion lights,
First one had SAUWA sticker not sure about 2nd waved to both :)
saw a purple 32 and red 33 in bunbury today about 1-2ish. parked outside a closed paint store refuelling the cars with jerry cans...
not sure if they were running ethanol or didnt think you could buy 98 in bunbury :whistling:
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
