and again today! Dude you just moved into the neighborhood or what? I see you most days now...
BTW, be careful driving around Curtin. We have lots of international students who either cant drive or shouldnt drive (legally) but do, and its dangerous as shit. iv avoided about 20 accidents (not kidding) over my 3 years there and also been cleaned up once.
silver R35 GTR. Seen you 3 times in the last week around Curtin in Bentley. I was in my red R33 gtst twice n my black R33 with Jun kit on it once.
Good to see a GTR getting driven how it should be :thumbsup:
Spotted 3 differant R33s on marmion, wanneroo and burns beach all 3 tried to race me which kind of got old a friendly wave responded with a revving of the engine, just because I'm on P plates doesn't mean I'm a hoon :/
Anyways white one with a jun bodykit I think was nice but sitting in the limiter in second isn't a good idea, sounds cool and all but eh...
Dear Unlucky owner of a white 33 gtst whom has been caught on armadale road tonight im guessing booze bus,
im feeling your pain as i drove past your car already on the back of the trailer of the truck they had ready for all their victim's for tonight
Gun metal grey R35 GTR in Bicton - on View Terrace to be exact turning down Westbury Crescent
I wasn't jealous at all :P
Oh and for what its worth, over the past 4 weeks have seen a Black Ferrari 599, Black Ferrari F430, Black Ferrari 458 and a Green Lambo, all at the Canning Hwy and Riseley St intersection! (Applecross)
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
