epic looking 10/10 champange colour (with matching rims) R34 GTR in mt lawley across from the Queens at about 6pm.
giggety.
I believe i saw this car last night from the Queens at about 7pm too. Car looked mint and sounded awesome.
Edited by wedge_r34gtr
Spotted- this rape victim at the end of my street.
I guess cul-de-sac burnouts didnt end well (thats not hektic camber on the front left wheel)
Awful nice of you to leave it in the middle of the culdesac too. Couldnt limp it to the curb either?
Is that como?
Looks like where a friend used to live.
Still seeing a grey 33 gtr around dalyellup/Bunbury regularly
Also black 32 gtst now lives in dalyellup near me too
yep, como/karawara border.
Damn boat has been sitting there 3 days now. Might report it as i may have been stolen. Saw it on the street the day before tho so issumed it was someones on the street or a friend of's...
Poor thing, sounded sweet with pipes on that quad cam V8...
  • 4 weeks later...
Sunday arvo about 2 a yellow Stagea with SAUWA sticker swerving all over Tonkin Hwy until he took the Guildford Rd exit .No wonder import drivers get such bad names when ya doing 120/130 in a 100 zone
Because race car
  • 3 weeks later...
  • 4 weeks later...
haha, sorry about that. From the brief glimpse i managed of u as i went past (was on the Suzuki GSXR 750- garden city lights, risely st) it looked like it was an older driver.
Having said that most of my brain power was devoted to ogling ur car n trying to think if it would be a genuine Nur or not :P
Nice wheels and kit choice too. :yes:
  • 3 weeks later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
