Hi all,
I am asking help again for my beloved skyline.
Only 2nd time in 4 years so not so bad
I try to do all my own work as most of you know its the only way to go as these cars are pretty
finnicky as they are complicated and GOOD
Anyway, it started idling rough when cold (always does this now)
Then it started on the road when at running temp
It basically can do it anytime (approx 50% of time now)
It can run absolutely perfect, then will start to splutter (idle or when driving) and then just comes good
At idle giving it a good rev seems to clearit for a while
When driving you just have to wait for it to come good.
I have noticed at idle when it happens, the tacho goes down and the boost guage goes UP.
Normally when you INCREASE the revs a bit the the boost goes up
Does this suggest a boost leak ? ...intermittant tho ?
I have changed the plugs and the fuel filter...no change (plugs are .8 gap ...same as before)
My car is an R33 GTST S2 (11 lb manual boost, FMIC, pod cold air, 3"cat back)
Any ideas anyone
https://www.sau.com.au/forums/topic/366400-help-with-my-r33-gtst/
Hi all,
Any ideas anyone
How long has it been happening ?
dirty fuel or injector ?
yeah feels like it
I have changed fuel filter and my fuel economy is much better
But hasn't fixed problem
I have put a few bottles of injector cleaner thru but still could be injectors
Its been happening a few weeks now
But I don't wnat to go to the hassle and expense of injector clean if its not going to fix it
Any suggestions please would be appreciated as I am short of readies at the mo
isn't that the afm dry solder problem.........thought I read it somewhere. There's a DIY on here on how to fix it too I think. Cos I could be wrong.
I will try it on the weekend
Cheers I didn't think of that
Have read it before as well!
Thanks mate fixed all my problems
By the way all joints looked Ok but obviously weren't
