Selling these as ive bought another car which has most of these parts aleady installed so i no longer need.
Parts located in Sydney and would rather sell locally unless an interstate buyer covers interstate postage
Trust GREX oil cooler and relocator $650 trying to sell local if possible.
needs one the fittings on the relocator replaced otherwise good.
post-1164-0-63769300-1306927666_thumb.jpgpost-1164-0-56531300-1306927676_thumb.jpgpost-1164-0-54802300-1306927689_thumb.jpg
Tomei Type A poncams $600 inc postage These are for BNR32/BCNR33 (RB26DETT).
The Type A cams are designed to get stable idle and raise low-mid RPM torque,
the duration of EX camshaft is shorter. No head work required, simply drop in.
A252X A269IN lift in ex 9:15
Twin high mount manifold came off RB26 T2/T3 size $600
Sard 600cc injectors $500
R32/GTR A Pillar pod gauge holder(new) $40
Greddy cam gears to suit RB26(new)$400
HKS dump pipes(new)$700
Jeccs Z32 AFM $450
x 4 Auto Gauge smoke ceremony gauges 3 stepper type one non (new) $300 for the set
throwing in sender plates and gauge panel for R32 GTR Boost oil pressure water temp oil temp
Sard FPR genuine $80
Tomei sump baffle kit $170 for RB26
feel free to pm me for more infromation and postage prices pick up also avaiable,prices are firm at this stage.
I was told it was new yes, and it looks to be!(i bought it second hand)but it hasnt been put together as yet. i can send see pics if your still interested.
apologies, inbox should be good now.
forgot to mention im unsure on the ks on the cams i did buy them second hand but there seems to be very little wear on them , practically new!
Dumps and Pod holder SOLD
Cooler and relocator price drop $600
gauges still available and selling very cheap for a set with all you need to get them going,steering wheel also available!!
cooler/relo down to $500!!! bargin,Gauges and Momo steering wheel still available and going cheap!
will be posting them on ebay by the end of the week if unsold by that time,get in quick!
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
