Yep, still on Vale St, number 15. You might drive past it a couple of times, they only have a tiny little sign hanging on the fence lol, Andy still hasn't got the other sign from his old workshop.
It's next to Malaga Auto Rentals the big yellow building on the corner of Kiln and Vale :thumbsup:
https://www.sau.com.au/forums/topic/366438-hyperdrive/#findComment-5845630
    • Sorry for the confusion, I meant would there be heat buildup internally in the S3 that would be detrimental to the ecu situated under the seat but covered over as suggested
    • Navara? If it's a Bluebird, I might throw up in my mouth a little.
    • What heat build up are you asking about? Heat in the wiring providing the power to the Haltech, if remote mounted and power run via the fu(k-da-polees trick wire on the old ECU? Or heat from mounting an S3 inside an original case? I wouldn't run all the power for the Haltech through the trick wire. You just need the activation power. The main power would have to come from an appropriately fat feed. I wouldn't think you could fit the plastic body of a Haltech inside an original ECU case. They're pretty compact these days, but I don't think they're that compact.
    • Nope 馃榿 1999/2000 model
    • Would heat build up be no issue? Eg; Haltech S3
