Sydneykid...
I dont have Hicas either. My ride hieghts were similar too a little higher at the front as I found the small difference it made in weight transfer to the rear gave the rear a little more grip as my car seemed to lack at the rear a little....probably because of the negative camber which I never got around to fixing.
Cheers,
Russ
  • 3 weeks later...
So what's come of this? It's a month ago and no follow up.
When I imported my car, it had an aftermarket wheel with HICAS boss on it. I've since removed that wheel and replaced it with an original. I've lined up the dots on the wheel and steering column as closely as I can. Since then, my HICAS light comes on after 10km of driving but this doesn't bother me a great deal as it never did anything other than illuminate.
I had a wheel alignment done a couple of days ago, and since then, if I drive with a lot of acceleration when the car has an unlit HICAS light, the steering wheel angle becomes turned to the left about 20 degrees. The car doesn't pull in any direction, but the wheel is not straight. After the 10km of driving, the light illuminates, but the car has an incredible kick sideways. This is very disconcerting, as the first time I felt it I was mid corner doing over 100kph and I nearly lost it.
I'm going to ring the alignment place tomorrow and try to get it back in with them this Thursday... I can't leave the car like this, it's far too dangerous.
Nick
Did you make sure that the lug for the hicas is in its slot at the bottom of the wheel. Its a small flat tongue that sticks out about 1cm from memory - if not aligned properly in its slot can, apparently, cause problems. This is why you must buy a hicas boss kit for aftermarket steering wheels.
About the only thing I can think of, hope it helps.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively. ย  Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... ๐Ÿ˜›
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February updateย ๐Ÿ™‚ We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.ย  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
ร—
ร—
