Hi all,
Before the standard "Use the search function" response will be used - I have searched and there is very little regarding this issue using a OEM routed swaybar.
This topic is regarding installing an RB30DET into a R32 GTST.
Currently, my sump (High Energy style) is clashing with my sway bar. My engine mounts have been modified as per the PDF (potentially slightly lower engine position) but this has led to the sump hitting the Whiteline sway bar (SK group buy spec).
My question is what have people done to get around this issue?
On initial glance, my solution would be to space the sway bar down at the chassis mounts. Use a longer bolt and washer. The only issue I can see is that the link pins/drop links will no longer be long enough. However, this is easily overcome by either modifying the standard links or purchasing aftermarket ones.
The only practical downside I can see from that is the sway bar may end up lower than the cross member which in the vent of bottoming the car out, the sway bar will scrape/bend. So long as the link pins are actuating the sway bar perpendicular to the lever arm on the sway bar, kinematically I see no change.
Any other ideas/options?
All input appreciated.
Cheers,
David
https://www.sau.com.au/forums/topic/366496-sump-is-hitting-sway-bar/
Whiteline sell an S-link kit for the sway bar which would give you some adjustment i believe.
Thing is, I dont think the amount you will need to space it will alter much at all. A 10mm drop would do SFA to the spherical ball joints on the links.
Just how far out is it do you think?
Well realistically speaking, the engine mounts have been modified as per the RB30DET PDF, so in saying that it should be clashing at a MAXIMUM of about 10-15mm.
Car is at my engine builders as he is installing it, so dont have the car on hand to measure/take pictures.
Just wondering if there are any other ideas other than the above mentioned fixes?
Heat up the sump and modify it with a hammer (does it have gates and baffles inside? Modify them first).
This has got to be the dumbest idea I have ever heard...
Mate this is not a personal attack, and I generally respect your posts as a whole... But this is WRONG.
DO NOT play games with the motors life blood, RB's are plaigued with oil problems as it is. Why create another?
Your criticism is welcome! I actually meant it quite literally at the time - easy fix to modify tin sump to accommodate a few mm but I guess it needed a little more thought...
I had the same problem in my cefiro.
It just slightly touches.
those whiteline S/ 8 looking links are rubbish, imho.
My car is street/ drift and like all of my cars, usually set up with soft susp and big sway bars.
I thought I'd try a heavier setup with no front swaybar for a change,
If its rubbish, custom swaybar is the go.
I tried spacing the stocker down, but wasnt happy with the results I got.
If it was a stock sump I would just notch / ive the sump a small releif.
Yeh...problem is that I dont want to have to get another sway-bar since I have already paid for this upgraded one. Sure I could sell it, but its just another hassle I don't want to have to deal with.
I think spacing the sway bar down will be the way to go. If necessary I will get those whiteline S Links. My standard links need replacing anyway.
If I still have problems, guess the way forward will be to modify the sump, or get a new swaybar...neither of which I will like doing.
  • 4 weeks later...
Finally dropped the 30 back in the car last night and with the engine mounts bolted with stock holes there is about 10mm clearance between the swaybar and ASR sump, will throw a couple of shitty pics up later.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
