Hi all,
Before the standard "Use the search function" response will be used - I have searched and there is very little regarding this issue using a OEM routed swaybar.
This topic is regarding installing an RB30DET into a R32 GTST.
Currently, my sump (High Energy style) is clashing with my sway bar. My engine mounts have been modified as per the PDF (potentially slightly lower engine position) but this has led to the sump hitting the Whiteline sway bar (SK group buy spec).
My question is what have people done to get around this issue?
On initial glance, my solution would be to space the sway bar down at the chassis mounts. Use a longer bolt and washer. The only issue I can see is that the link pins/drop links will no longer be long enough. However, this is easily overcome by either modifying the standard links or purchasing aftermarket ones.
The only practical downside I can see from that is the sway bar may end up lower than the cross member which in the vent of bottoming the car out, the sway bar will scrape/bend. So long as the link pins are actuating the sway bar perpendicular to the lever arm on the sway bar, kinematically I see no change.
Any other ideas/options?
All input appreciated.
Cheers,
David
https://www.sau.com.au/forums/topic/366496-sump-is-hitting-sway-bar/
Whiteline sell an S-link kit for the sway bar which would give you some adjustment i believe.
Thing is, I dont think the amount you will need to space it will alter much at all. A 10mm drop would do SFA to the spherical ball joints on the links.
Just how far out is it do you think?
Well realistically speaking, the engine mounts have been modified as per the RB30DET PDF, so in saying that it should be clashing at a MAXIMUM of about 10-15mm.
Car is at my engine builders as he is installing it, so dont have the car on hand to measure/take pictures.
Just wondering if there are any other ideas other than the above mentioned fixes?
Heat up the sump and modify it with a hammer (does it have gates and baffles inside? Modify them first).
This has got to be the dumbest idea I have ever heard...
Mate this is not a personal attack, and I generally respect your posts as a whole... But this is WRONG.
DO NOT play games with the motors life blood, RB's are plaigued with oil problems as it is. Why create another?
Your criticism is welcome! I actually meant it quite literally at the time - easy fix to modify tin sump to accommodate a few mm but I guess it needed a little more thought...
I had the same problem in my cefiro.
It just slightly touches.
those whiteline S/ 8 looking links are rubbish, imho.
My car is street/ drift and like all of my cars, usually set up with soft susp and big sway bars.
I thought I'd try a heavier setup with no front swaybar for a change,
If its rubbish, custom swaybar is the go.
I tried spacing the stocker down, but wasnt happy with the results I got.
If it was a stock sump I would just notch / ive the sump a small releif.
Yeh...problem is that I dont want to have to get another sway-bar since I have already paid for this upgraded one. Sure I could sell it, but its just another hassle I don't want to have to deal with.
I think spacing the sway bar down will be the way to go. If necessary I will get those whiteline S Links. My standard links need replacing anyway.
If I still have problems, guess the way forward will be to modify the sump, or get a new swaybar...neither of which I will like doing.
  • 4 weeks later...
Finally dropped the 30 back in the car last night and with the engine mounts bolted with stock holes there is about 10mm clearance between the swaybar and ASR sump, will throw a couple of shitty pics up later.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
