Car - 180sx
Engine bay:
Engine - RB25
RB25 Gear box
Garrett GT3582R .82ar
turbo has been hpc coated
6Boost manifold
Link G4 ECU
GFB 50mm Gate to screamer pipe
Greddy plenum
custom billet fuel rail
1000cc injector dynamics injectors
2x walbro intank fuel pumps - adding surge tank and Bosch 044 pump
turbo smart blow off valve
custom dump pipe
600x300x100 fmic
JJR 19row oil cooler
oil catch can
HI TORQUE solid centre heavy duty clutch
alloy radiator
2x thermo fans (work by the ECU)
powersteering spacer for more lock
superspark coil packs
hi-cas powersteering pump
Q45 throttle body
Engine Work:
full valve service
crack tested head
bleed and clean hydraulic lifters
chemical clean and acid dip block
deck block
TOMEI head gasket
head reconditioned
bottom end machined
ARP head studs
HI ENERGY pro eliminator sump (HUGE)
nismo oil pump
CP piston kit 20 thou
CP Piston rings
ARP main studs
main bearings
rod bearings
GATES racing timing belt + full timing kit
Incar:
autometer cobalt monster tacho
boost gauge
oil temp
oil pressure
custom brake lines for hydrolic handbrake
Velo seat - still need to get rails for so have a s15 seat ATM
s15 passenger seat
full roll cage with padding
hyrdo handbrake and normal handbrake aswell
carpet is gone
full race harness
battery relocated in rear
Outside:
180sx Full Works body kit
5 stud conversion
32gtr front brake upgrade
clear tail lights
rattlecan matt black paint job
white 18inch wheels
custom 3" exhaust with twin 3" outlets
racing logic coilovers
all the bells and whistles in suspension including strut braces,tie rod ends etc
https://www.sau.com.au/forums/topic/366503-damits-180sx/
  • 1 month later...
  • 4 weeks later...
I'm building an rb25 gt35 silvia atm, So jelly you have had yours on the track pinch.gif
Have you weighed it?
Apparently due to the large rear windscreen 180's are heavier than silvias... I would be interesting to see how much it weighs
https://www.sau.com.au/forums/topic/366503-damits-180sx/#findComment-6000405
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
