This topic has probably been covered a million times but i cant find it.
Just wondering how much a power an rb25 with stock internals can handle all day every day on a safe tune?
My current project is: rb25det (standard motor)
550cc injectors
hks gt2530 turbo
14 psi boost
apexi power fc
z32 afm
hks pod filter
hks fmic
hks 3.5 inch turbo back exhaust
If there is already a write up can someone please let me know.
Cheers
  • Replies 110
awesome. Id be happy with 250-270 and i drive pretty hard, so i reckon i'll be sweet. As long as i get it tuned properly like you said
Your going to be very unhappy then.
As has been said 230kw is doable from one pushing it as hard as it can go. Friend had a HKS 2535 Kai on his and the most that ever saw was high 230s/low 240s.
Far out Mr Ash, hell I try and be specific about "@ hubs" but still occasionally let "@ wheels" slip, its easy to do given the difference in many cases is negligable and its basically more to quantify that it wasn't on an engine dyno. If you want to get pedantic you may as well make a forum rule that every time someone says a dyno result they say:
Ambient Temp:
Ambient Pressure:
Tyre Pressure:
Tyre Size:
Tyre Profile:
Tyre Temperature:
Tyre Type:
Gearbox type:
Dyno Type:
Dyno Correction method:
Air Intake Temperature location:
Ramp rate:
Tie down method:
But thats just taking silly and running with it :)
It's not occasional in this instance (otherwise i totally agree with ya). Back-to-back testing was done by another user that shows that particular hub dyno reads a solid 40-60kw different. That's a bit more than 2 degree change in ambient temperature :thumbsup:
I say all this because of the thread title "How much can a standard RB25 handle".
People get it in their heads that it's ok to run around making "350rwkw+" when people go around making false claims, when realistically thats really taking a gamble and not a good idea at all.
Over the next 12 months i think we might see a few more 300-320rwkw RB25's fail as there are a few users who have been around that mark now for 2-3 years. So perhaps even 300rwkw isn't that safe.
We have to remember that not everyone wants to go through the expense/drama of a dead motor/rebuild
Fwiw my motor lasted 3 years on 285rwkw pulp and 325rwkw e85 before it finally munched a bearing
That motor was a series 1, 1993 built, 250,000km engine and was a track car of some sort in Japan for god knows how long
Thing saw 7000 revs every time it ran, without fail and was dailied and tracked
End of the day whenever you decide to mod the car and start pushing high 200,s plus on stock engine we all do it knowing all well that theres a chance that the engine might die sooner than expected but theres to many variables how you drive , how much you drive it, and of course the tune.
Of course a car tuned at 350kw which is a daily and never sees all that power being put down will last longer then someone at 280kw thats smashing track work constantly. But atm it seems like the median of what people go on stock is 300kw and also consider running on e85 for abit more security.
550cc injectors
hks gt2530 turbo
14 psi boost
apexi power fc
z32 afm
hks pod filter
hks fmic
Cheers
about twice as much as your turbo can deliver.
Ash this may interest you as i know your a racepace (killer workshop) fan boy.
We see quite a few cars from Racepace through nowadays and the results we see from our hub dyno are very close to the dyno dynamics dyno (generally 10 up or down) they are running... so hub versus roller is moot.
In fact only last week had a bayside blue R34 gtr with t518z's from there last week which pulled 280kw on mine and he had a dyno sheet for 290 from racepace exact same boost.
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
