  • Replies 110
dp..
Dont be a smart ass John :P btw that radiator shroud you sold me was broken.
But basically what I said before about low comp and excessive piston blowby was right. Probably worn valveseats and springs as well but in Laymans terms, yes engine was tired.. :D
Just the way you were talking I thought there was something you had changed but werent telling us what it was. :unsure:
Except for the big end bearing that lunched itself ;)
Nah, setup is exactly the same. I was jus making the point that my ol motor that had held ~ 300rwkw for 3 years was getting on.
There is no definatel answer as the old motor hasn't been pulled down yet.
I'll chime in here. Since I've had my car for 300,000k's I think I can answer this often repeated question. How much power can an RB25 make ? Anything from 250 to 300rwk. However, Ask more the question, "how hard do I drive", "who tuned it", "what's my setup and how many short cuts did I take ?"
I've been through a couple of engines now and I know when I pulled apart my first it was as clean as a whistle inside apart from bent valves, a long story. It had been caned. Unichip and usual mods at 215kws.
Motor number two is still in the car and also around the same kay's on it. Still strong but tuned it myself and though it has some track days under it's belt it has an easy life now.
Both motors are stock internally. The secret I think is that both motors have never been beyond 6,800rpm. They had their oil changed every 5,000k's. Fresh plugs and coils if there was any doubt at all if they needed replacing. I had set the rev limit low because I was never going to have a turbo that would make power in the top end. Mind you 268rwkws is enough anyway.
I don't where everyone gets the impression these motors are indestructable as they pop on a regular basis especially with the home mechanics that make the dumbest mods then thrash them without so much as a run on the dyno. They are just another motor, better than some but not as good as some others.
not at the moment...
will go back there soon with a vipec and a content sensor.
my laptop wont recognise my datalogit, so changing maps is a PITA atm... when i have the time i'll get it sorted again
also... a mega responsive 280rwkw is easily enough for a 33gtst
rework of the old one...
car is nicer to drive all round... even idles better
haven't got the boost graph on USB, but i have the printout and 18psi is just nudging 3200rpm
yeah i bet it does, once your valve springs get sloppy it all falls to shit really, allthough it was still in pretty good nick considering. Would be interesting to know what the comp was like too. would be cool to see how your car goes against Kris with the 3076 and 280kw..
:D awesome
You are making 18psi 4-500rpm before me, and 10kw up on me everywhere..... fag.
Interesting you should say that... I have driven both cars and they are actually very different for what is exactly the same power.
Kris's is much more linear and slower to build. Feels a lil doughy after mine. You can definitely notice the difference with the bigger turbo. Having said that however, kris's car could be seeing 20rwkw over mine if he pushed it a lil more.
Im was running with 240rwkw at 1bar thru auto on my S1 rb25det Stagea. Bottom end has finally let go after a handful of trackdays, compression in cylinder#5 is v.low.
Looking to rebuild the block in a few months time with N1 oil & water pumps, a fresh nismo timing belt kit, wiseco 87mm pistons with manley rods, arp rod bolts & main studs, acl race bearings, a fresh full cometic streetpro gasket set, extended crank collar, & honing the block to suit. I'll be upgrading the 450cc S15 injectors to 600cc and installing a Nistune Z32ecu to replace the Toshi remap and AEM Fic-8 piggyback ecu.
The head has been ported a few years ago, setup with tomei cams and springs, etc. Turbo is a GT3076iw. Everything already done is strong and ready for a forged bottom end.
What Im not sure about is whether I should get a Ross harmonic balancer and under-driven pulley set, and whether I should bother thinking about a reimax N1 oil pump gearset or a different oil pump altogether such as a Nismo oil pump for around $1100del. Engine would probably not see track work again, but I would like to up the power by around 30rwkw for an end result of at least 270awkw from 16-18psi from the auto/awd stagea.
^^ swap the wisecos for... anything else :P im a wiseco fan (all my bikes run them) but not a fan of their rb pistons.
cheers for that info - it'll be CP pistons then with either eagle or manley rods then.
probably will keep to stock balancer, and standard N1 pumps to keep the costs down a bit.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
